I am currently attempting to convert a project from a DUE to GIGA R1. The code samples the ADC at what I believe is 1MHz, applies a low pass filter. I have most of the functionality completed but, I am having some issues with getting the ADC to sample at the correct rate. I this is the original code:
void ADC_Handler() {
int adc_stat= adc1.ADC_ISR
//int adc_stat = ADC->ADC_ISR;
if (adc_stat & ADC_ENDRX) {
// Show that we've filled a buffer with ADC samples.
buf_full = true;
ADC->ADC_CR = ADC_SWRST;
// Prep the ADC for acquisition.
void adc_setup (void) {
// Init ADC for 1 MHz acquisition.
adc_init (ADC1, SystemCoreClock, 21000000, 10000);
// Set ADC to be free running.
ADC->ADC_MR |= 0x80;
// ADC channel 7 maps to Due analog pin 0.
ADC->ADC_CHER = ADC_CH7;
NVIC_EnableIRQ (ADC_IRQn);
// There is no next buffer - only one.
ADC->ADC_RNPR = NULL_BUF;
ADC->ADC_RNCR = 0;
// Enable receiver DMA.
ADC->ADC_PTCR = ADC_PTCR_RXTEN;
// Point to the sample buffer.
ADC->ADC_RPR = (uint32_t) sample_buf;
// Enable ADC conversions.
ADC->ADC_CR = ADC_START;
// Show waiting on the buffer to fill.
buf_full = false;
void adc_start (unsigned int num_samples) {
// Start the ADC by (re)loading the conversion count.
ADC->ADC_RCR = num_samples;
// We have to enable the ENDRX interrupt AFTER we load RCR, else we'll get an interrupt the
// moment we enable the interrupt because ENDRX trips when RCR == 0 and that's what it will
// be until we load it.
ADC->ADC_IER = ADC_ENDRX;
// Wait for the ADC isr to show the buffer full.
while (!buf_full);
void do_sample (void) {
unsigned long holdoff = millis () + 0;
sendcounts(9999);
// Do the ADC setup - we're doing this in parallel with holding off the start of the
// acquisition so it doesn't cost anything.
adc_setup ();
// Delay from the recognition of the TRIGGER signal to let the ball get close to
// the force sensor before we start acquiring data from the ADC.
while ((long) (millis () - holdoff) < 0);
// Start the acquisition and wait for it to complete.
adc_start (NUM_SAMPLES_PER_BUF);
// Do the processing and output the result.
do_filter (NUM_SAMPLES_PER_BUF);
sendcounts (threshold (findpeak (), threshold_limit));
// Reset the trigger flag to prepare for the next acquisition.
trigger = false;
Some items like the ADC ISR stuff does not seem to exist in the GIGA AdvancedADC. Looking for information or links to what I am missing.
