I have been using the adafruit 3.5'' tft touchscreen break out board with arduino. It has arduino library available for this purpose. I have attached the library below. I am trying to make this touchscreen work without the arduino board with atmega16 . I have changed the library into a c file accordingly. I have written a program to just change the screen color, but that also in not happening. I do not understand where is the problem. can some one help me out. pls !!!
This the code after editing in c file .
#define SS PINB4
#define MOSI PINB5
#define MISO PINB6
#define SCK PINB7
#define CS PIND0
#define DC PIND1
#define RST PIND6
void delay(uint8_t a)
unsigned int i,j;
for(i=0;i<a;i++)
for(j=0;j<1024;j++);
void Adafruit_HX8357() {
_cs = CS;
_dc = DC;
_rst = RST;
_mosi = MOSI;
_sck = SCK;
void Adafruit_GFX(int16_t w, int16_t h)
_width = w;
_height = h;
rotation = 0;
cursor_y = cursor_x = 0;
textsize = 1;
textcolor = textbgcolor = 0x001F;
void setRotation(uint8_t m) {
writecommand(HX8357_MADCTL);
rotation = m % 4; // can't be higher than 3
switch (rotation) {
case 0:
writedata(MADCTL_MX | MADCTL_MY | MADCTL_RGB);
_width = HX8357_TFTWIDTH;
_height = HX8357_TFTHEIGHT;
case 1:
writedata(MADCTL_MV | MADCTL_MY | MADCTL_RGB);
_width = HX8357_TFTHEIGHT;
_height = HX8357_TFTWIDTH;
case 2:
writedata( MADCTL_RGB);
case 3:
writedata(MADCTL_MX | MADCTL_MV | MADCTL_RGB);
void writecommand(uint8_t c) {
PORTD &= ~(1<<PIND1);//
//dcport &= ~dcpinmask;
//digitalWrite(_dc, LOW);
PORTB &= ~(1<<PINB7);//clkport &= ~clkpinmask;
//digitalWrite(_sclk, LOW);
PORTD &= ~(1<<PIND0);//*csport &= ~cspinmask;
//digitalWrite(_cs, LOW);
spiwrite(c);
//Serial.print("Command 0x"); Serial.println(c, HEX);
PORTD |= (1<<PIND0);//*csport |= cspinmask;
//digitalWrite(_cs, HIGH);
void writedata(uint8_t c) {
PORTD |= (1<<PIND1);//
//dcport |= dcpinmask;
//digitalWrite(_dc, HIGH);
PORTD &= ~(1<<PIND0);// *csport &= ~cspinmask;
spiwrite(c);
//Serial.print("Data 0x"); Serial.println(c, HEX);
void spiwrite(uint8_t c) {
SPDR = c;
while(!(SPSR & (1<<SPIF) ));
void init()
DDRB = (1<<PINB5)|(1<<PINB7);
SPCR = 0x50;
SPSR = 0x00;
void begins(uint8_t type) {
if (_rst > 0) {
DDRD |= (1<<PIND6);//pinMode(_rst, OUTPUT);
_rst = 0;// reset LOW
DDRD |= (1<< PIND1);//pinMode(_dc, OUTPUT);
DDRD |= (1<< PIND0);//pinMode(_cs, OUTPUT);
// toggle RST low to reset
if (_rst > 0) {
_rst = 1;//digitalWrite(_rst, HIGH);
delay(100);
_rst = 0;//digitalWrite(_rst, LOW);
delay(100);
delay(150);
writecommand(HX8357_SWRESET);
// setextc
writecommand(HX8357D_SETC);
writedata(0xFF);
writedata(0x83);
writedata(0x57);
delay(300);
// setRGB which also enables SDO
writecommand(HX8357_SETRGB);
writedata(0x80); //enable SDO pin!
// writedata(0x00); //disable SDO pin!
writedata(0x0);
writedata(0x06);
writedata(0x06);
writecommand(HX8357D_SETCOM);
writedata(0x25); // -1.52V
writecommand(HX8357_SETOSC);
writedata(0x68); // Normal mode 70Hz, Idle mode 55 Hz
writecommand(HX8357_SETPANEL); //Set Panel
writedata(0x05); // BGR, Gate direction swapped
writecommand(HX8357_SETPWR1);
writedata(0x00); // Not deep standby
writedata(0x15); //BT
writedata(0x1C); //VSPR
writedata(0x1C); //VSNR
writedata(0x83); //AP
writedata(0xAA); //FS
writecommand(HX8357D_SETSTBA);
writedata(0x50); //OPON normal
writedata(0x50); //OPON idle
writedata(0x01); //STBA
writedata(0x3C); //STBA
writedata(0x1E); //STBA
writedata(0x08); //GEN
writecommand(HX8357D_SETCYC);
writedata(0x02); //NW 0x02
writedata(0x40); //RTN
writedata(0x00); //DIV
writedata(0x2A); //DUM
writedata(0x0D); //GDON
writedata(0x78); //GDOFF
writecommand(HX8357D_SETGAMMA);
writedata(0x02);
writedata(0x0A);
writedata(0x11);
writedata(0x1d);
writedata(0x23);
writedata(0x35);
writedata(0x41);
writedata(0x4b);
writedata(0x4b);
writedata(0x42);
writedata(0x3A);
writedata(0x27);
writedata(0x1B);
writedata(0x08);
writedata(0x09);
writedata(0x03);
writedata(0x02);
writedata(0x0A);
writedata(0x11);
writedata(0x1d);
writedata(0x23);
writedata(0x35);
writedata(0x41);
writedata(0x4b);
writedata(0x4b);
writedata(0x42);
writedata(0x3A);
writedata(0x27);
writedata(0x1B);
writedata(0x08);
writedata(0x09);
writedata(0x03);
writedata(0x00);
writedata(0x01);
writecommand(HX8357_COLMOD);
writedata(0x55); // 16 bit
writedata(0xC0);
writecommand(HX8357_TEON); // TE off
writedata(0x00);
writecommand(HX8357_TEARLINE); // tear line
writedata(0x00);
writedata(0x02);
writecommand(HX8357_SLPOUT); //Exit Sleep
delay(150);
writecommand(HX8357_DISPON); // display on
delay(50);
void drawPixel(int16_t x, int16_t y, uint16_t color) {
if((x < 0) ||(x >= _width) || (y < 0) || (y >= _height)) return;
setAddrWindow(x,y,x+1,y+1);
PORTD |= (1<<PIND1);// dcport |= dcpinmask;
PORTD &= ~(1<<PIND0);//csport &= ~cspinmask;
spiwrite(color >> 8);
spiwrite(color);
void drawFastVLine(int16_t x, int16_t y, int16_t h,uint16_t color) {
// Rudimentary clipping
if((x >= _width) || (y >= _height)) return;
if((y+h-1) >= _height)
h = _height-y;
setAddrWindow(x, y, x, y+h-1);
uint8_t hi = color >> 8, lo = color;
PORTD |= (1<<PIND1);//*dcport |= dcpinmask;
while (h--) {
spiwrite(hi);
spiwrite(lo);
void drawRect(int16_t x, int16_t y, int16_t w, int16_t h,uint16_t color) {
drawFastHLine(x, y, w, color);
drawFastHLine(x, y+h-1, w, color);
drawFastVLine(x, y, h, color);
drawFastVLine(x+w-1, y, h, color);
void drawFastHLine(int16_t x, int16_t y, int16_t w,uint16_t color) {
if((x+w-1) >= _width) w = _width-x;
setAddrWindow(x, y, x+w-1, y);
while (w--) {
spiwrite(hi);
spiwrite(lo);
void fillScreen(uint16_t color) {
drawRect(0, 0, _width, _height, color);
void setAddrWindow(uint16_t x0, uint16_t y0, uint16_t x1,uint16_t y1)
writecommand(HX8357_CASET); // Column addr set
writedata(x0 >> 8);
writedata(x0 & 0xFF); // XSTART
writedata(x1 >> 8);
writedata(x1 & 0xFF); // XEND
writecommand(HX8357_PASET); // Row addr set
writedata(y0>>8);
writedata(y0); // YSTART
writedata(y1>>8);
writedata(y1); // YEND
writecommand(HX8357_RAMWR); // write to RAM
void setCursor(int16_t x, int16_t y) {
cursor_x = x;
cursor_y = y;
void setTextSize(uint8_t s) {
textsize = (s > 0) ? s : 1;
void setTextColor(uint16_t c) {
textcolor = textbgcolor = c;
int main(void)
init();
Adafruit_HX8357();
begins(HX8357D);
Adafruit_GFX(HX8357_TFTWIDTH, HX8357_TFTHEIGHT);
setRotation(3);
fillScreen(HX8357_RED);
return 0;
The link for original library is
