One of the problems I've encountered with past Arduino projects is that I build a cool project using shields and maybe a few additional sensors. I then want to take my project to completion by creating a PCB, but I've struggled with that part of the process.
I'm curious if there are others out there who have encountered a similar issue? Or if others mostly want to create a working prototype and tear it down to build the next one.
What's the problem? It's a long road you're on. It's challenging to do a final product especially if you're talking about going to market. You will run into problems and challenges that you never considered or worried about in prototype stage.
I have a customer with a commercial product using an Arduino NANO, along with some other circuit boards, all in a nice box. I bet you could something similar with your project.
This is one of my current projects, an RFID pet feeder. This is fine for a couple of prototypes, but I have been thinking about producing in higher quantities, and it's pretty difficult to assembly / mount as is.
I guess what I'm envisioning is a single PCB that is not only easy to mount but also to wire components into.
Paul, did your customer find a good solution for mounting and wiring the separate PCBs?
Nice and clean setup, I would be leaving everything as is, but fitting sockets to the large PCB and then making a loom with 0.1" connectors to go into both boards.
You already have header sockets on the micro.
Well, yes. Designing and prototyping the project, and preparing the project to actual "manufacturing" are essentially different skill sets (and the "take orders and ship stuff" skills, and the business skills that go with running everything are yet again separate skills.)
I don't know how small companies manage to do it.
Large companies have separate people. Even separate "departments." (at good large companies, they talk to each other, so that there aren't any major surprises that show up at some unexpected point.)
You get better at PCB design with practice. Presumably, if you actually get things manufactured, you get better at designing the PCB to be manufactured, as well (which is a separate thing.) There are blogs and books and various people that will give you advice. Or you can hire someone else - you might find someone good. Or not.
westfw:
You just need to find the right small company to work with. I convert collections of boards/shields into single board designs for folks on a regular basis, with the outcome the PCB Gerber files and a BOM of Digikey/Mouser parts if desired. If the design is not too complex for hand assembly, we even assemble batches of cards.
