Converting bytes to char when receiving from 433mhz
I am trying to combine the buf[] received into a char (strRec).
The Serial.print((char)buf[i]); prints the correct information received.
This is not a project so any assistance would be appreciated.
#include <VirtualWire.h>
   sent example =  A001*, A002* etc
  Serial.begin(115200); // Debugging only
  Serial.println("Receiver setup");
  // Initialise the IO and ISR
  //  vw_set_ptt_inverted(true); // Required for DR3100
  vw_set_rx_pin(11);           // Arduino pin (default 11)
  vw_setup(2000);             // Bits per sec
  vw_rx_start();              // Start the receiver PLL running
  char strRec;
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(buf, &buflen)) // Non-blocking
    digitalWrite(13, true); // Flash a light to show received good message
    // Message with a good checksum received, dump it
    for ( int i = 0; i < buflen; i++)
      **strRec += ((char)buf[i]);**
    Serial.print(" received: "); Serial.print(strRec);
    digitalWrite(13, false);
    delay(200);
strRec is a single character - it isn't going to hold a very large sum.
What do you want here?
I want to add the character's received into one string.
If your received message is buflen chars, just copy them over
    char newBuffer[VW_MAX_MESSAGE_LEN];
    memcpy(newBuffer, buf, buflen);  // copy the contents
    newBuffer[buflen] = '\0';  make sure string is nul terminated
    Serial.print(newBuffer);
vw_get_message() stays right there until the ENTIRE MESSAGE is received.
That function Blocks! The code that uses the data expects it all, there's no exit or re-entry, execution stays Locked on vw_get_message that receives chars over time.
Beyond that.... '\0' is ASCII 48, text zero. The NUL is ASCII 0.
Perfect thank you.
