converting char into integer
Hi. I have such a question, how can I convert some char into int? Example: char a =23.50; and I need to get the same number 23.50 but integer form.
Can anyone help please?
A char cannot contain a floating point value.
You can use a float to do what you ( may ) want.
float f = 23.5f;
int i = f;
However the decimal portion is dropped and i = 23, not 23.50, or 23.00
Maybe you have a string ( of chars )?
int i = atoi( "23"  );
//Or
float f = atof( "23.50" );
actually i get the char data from serial read as you can see from my code
      Serial.begin(9600); // Initialize serial port to send and receive at 9600 baud
 while (Serial.available())
   char angle = Serial.read();
    Serial.print(angle);
and the reading in serial monitor is like this -0.24 -0.25 -0.3 -0.3 -0.25 -0.24 -0.23 -0.23 -0.32 -0.37 -0.4 -0.65 -0.93 -1.21 -2.94 -4.8 -5.24
Several things: 1) data coming from the serial port is being read one byte at a time, so if “-0.24” is coming from a Serial.read(), all angle is going to get is “-”. 2) You can convert 23.50 into an int if you want, but all you’re going to get is 23. The int data type cannot have a fractional component. That is, everything after the decimal point is ignored.
What marks the end of one of your values coming in via Serial.read()? If it is terminated with a newline character (’\n’), you might try: Serial.readByteUntil(’\n’, buffer, 10), which says read all the bytes you find up to the newline character and save them in buffer[]. Note that buffer[] is defined as a character array with up to 10 elements:
char buffer[10];
Then you could use dtostrf() to convert buffer[] into a floating point number.
than you so much it is very helpful information. but i have some confusing in how to write the code comparing with my code can you help me in this part? my regard
Try this…
  char buffer[] = "-23.5";  // Note this MUST be an array of characters...
  int val;
  val = atof(buffer);
  Serial.println(buffer);
Ok, but i don't want to convert only one value. i need to convert all values that received from serial read and need to located on void loop.
