I'm relatively new to Arduino coding and somewhat know the basics. For my work, we are building a heat shrink cutter using the design linked below. This is a project I took over several months ago after taking it over from someone else.
[Handy machine cuts heat shrink tubing to length | Arduino Blog]
The code is already written. However my predecessor seems to have purchased an Arduino Nano 33 IoT instead of the basic Nano that is listed in the design. I'm aware that the 33 IoT doesn't use elements of the code that is written, such as the SoftwareSerial library. I'm not sure how to convert the code to work for the 33 IoT, if that is even possible.
Below should be the code that comes with the project, for the basic Arduino Nano.
#include <Stepper.h>
#include <Arduino.h>
#include "BasicStepperDriver.h"
#include <Servo.h>
SoftwareSerial mySerial(2, 3); // RX, TX
Servo myservo;
int A = 0;
int B = 0;
int state = 0;
int QTY, numMessages, endBytes;
byte inByte;
int flag = 0;
#define MOTOR_STEPS 200
#define RPM 40
#define MICROSTEPS 16
#define DIR 14
#define STEP 15
int pos = 0;
BasicStepperDriver stepper(MOTOR_STEPS, DIR, STEP);
numMessages, endBytes = 0;
mySerial.begin(9600);
myservo.attach(5);
myservo.write(180);
stepper.begin(RPM, MICROSTEPS);
data();
if (A > 0 && B > 0) {
myservo.write(70);
for (int i = 0; i < B; i++) {
stepper.rotate(-(2.75*A));
cut();
A=0;
B=0;
void data() {
if (state < 1) {
if (numMessages == 1) { //Did we receive the anticipated number of messages? In this case we only want to receive 1 message.
A = QTY;
// Serial.println(A);//See what the important message is that the Arduino receives from the Nextion
numMessages = 0; //Now that the entire set of data is received, reset the number of messages received
state = 1;
if (state > 0) {
B = QTY;
// Serial.println(B);//See what the important message is that the Arduino receives from the Nextion
state = 0;
if (mySerial.available()) { //Is data coming through the serial from the Nextion?
inByte = mySerial.read();
// Serial.println(inByte); //See the data as it comes in
if (inByte > 47 && inByte < 58) { //Is it data that we want to use?
message.concat(char(inByte)); //Cast the decimal number to a character and add it to the message
else if (inByte == 255) { //Is it an end byte?
endBytes = endBytes + 1; //If so, count it as an end byte.
if (inByte == 255 && endBytes == 3) { //Is it the 3rd (aka last) end byte?
QTY = message.toInt(); //Because we have now received the whole message, we can save it in a variable.
message = ""; //We received the whole message, so now we can clear the variable to avoid getting mixed messages.
endBytes = 0; //We received the whole message, we need to clear the variable so that we can identify the next message's end
numMessages = numMessages + 1; //We received the whole message, therefore we increment the number of messages received.
//Now lets test if it worked by playing around with the variable.
void cut (){
for (pos = 70; pos <= 180; pos += 1) {
myservo.write(pos);
delay(5);
for (pos = 180; pos >= 70; pos -= 1) {
// in steps of 1 degree
myservo.write(pos);
delay(10);
}This text will be hidden
If someone is able to clear up how and why things need to be changed it would be greatly appreciated.
