Converting code to stm32duino
There’s an example sketch written for avr that I’d like to run on a stm32duino platform (part of 3d printer build)
The sketch works fine on avr, but it involves bits I don’t understand, so don’t know how to convert.
Could anyone pelase help me convert this? It’s stallguard exampel from tmcstepper library
 * Author Teemu Mäntykallio
 * Plot TMC2130 or TMC2660 motor load using the stallGuard value.
 * You can finetune the reading by changing the STALL_VALUE.
 * This will let you control at which load the value will read 0
 * and the stall flag will be triggered. This will also set pin DIAG1 high.
 * A higher STALL_VALUE will make the reading less sensitive and
 * a lower STALL_VALUE will make it more sensitive.
 * You can control the rotation speed with
 * 0 Stop
 * 1 Resume
 * + Speed up
 * - Slow down
#include <TMCStepper.h>
#define MAX_SPEED        40 // In timer value
#define MIN_SPEED      1000
#define STALL_VALUE      15 // [-64..63]
#define EN_PIN           38 // Enable
#define DIR_PIN          55 // Direction
#define STEP_PIN         54 // Step
#define CS_PIN           42 // Chip select
#define SW_MOSI          66 // Software Master Out Slave In (MOSI)
#define SW_MISO          44 // Software Master In Slave Out (MISO)
#define SW_SCK           64 // Software Slave Clock (SCK)
#define R_SENSE 0.11f // Match to your driver
                      // SilentStepStick series use 0.11
                      // UltiMachine Einsy and Archim2 boards use 0.2
                      // Panucatt BSD2660 uses 0.1
                      // Watterott TMC5160 uses 0.075
// Select your stepper driver type
//TMC2130Stepper driver(CS_PIN, R_SENSE);                           // Hardware SPI
//TMC2130Stepper driver(CS_PIN, R_SENSE, SW_MOSI, SW_MISO, SW_SCK); // Software SPI
//TMC5160Stepper driver(CS_PIN, R_SENSE);
//TMC5160Stepper driver(CS_PIN, R_SENSE, SW_MOSI, SW_MISO, SW_SCK);
using namespace TMC2130_n;
// Using direct register manipulation can reach faster stepping times
#define STEP_PORT     PORTF // Match with STEP_PIN
#define STEP_BIT_POS      0 // Match with STEP_PIN
ISR(TIMER1_COMPA_vect){
  //STEP_PORT ^= 1 << STEP_BIT_POS;
  digitalWrite(STEP_PIN, !digitalRead(STEP_PIN));
  SPI.begin();
  Serial.begin(250000);         // Init serial port and set baudrate
  while(!Serial);               // Wait for serial port to connect
  Serial.println("\nStart...");
  pinMode(EN_PIN, OUTPUT);
  pinMode(STEP_PIN, OUTPUT);
  pinMode(CS_PIN, OUTPUT);
  pinMode(DIR_PIN, OUTPUT);
  pinMode(MISO, INPUT_PULLUP);
  digitalWrite(EN_PIN, LOW);
  driver.begin();
  driver.toff(4);
  driver.blank_time(24);
  driver.rms_current(400); // mA
  driver.microsteps(16);
  driver.TCOOLTHRS(0xFFFFF); // 20bit max
  driver.THIGH(0);
  driver.semin(5);
  driver.semax(2);
  driver.sedn(0b01);
  driver.sgt(STALL_VALUE);
  // Set stepper interrupt
    cli();//stop interrupts
    TCCR1A = 0;// set entire TCCR1A register to 0
    TCCR1B = 0;// same for TCCR1B
    TCNT1  = 0;//initialize counter value to 0
    OCR1A = 256;// = (16*10^6) / (1*1024) - 1 (must be <65536)
    // turn on CTC mode
    TCCR1B |= (1 << WGM12);
    // Set CS11 bits for 8 prescaler
    TCCR1B |= (1 << CS11);// | (1 << CS10);
    // enable timer compare interrupt
    TIMSK1 |= (1 << OCIE1A);
    sei();//allow interrupts
  static uint32_t last_time=0;
  uint32_t ms = millis();
  while(Serial.available() > 0) {
    int8_t read_byte = Serial.read();
    #ifdef USING_TMC2660
      if (read_byte == '0')      { TIMSK1 &= ~(1 << OCIE1A); driver.toff(0); }
      else if (read_byte == '1') { TIMSK1 |=  (1 << OCIE1A); driver.toff(driver.savedToff()); }
    #else
      if (read_byte == '0')      { TIMSK1 &= ~(1 << OCIE1A); digitalWrite( EN_PIN, HIGH ); }
      else if (read_byte == '1') { TIMSK1 |=  (1 << OCIE1A); digitalWrite( EN_PIN,  LOW ); }
    #endif
    else if (read_byte == '+') { if (OCR1A > MAX_SPEED) OCR1A -= 20; }
    else if (read_byte == '-') { if (OCR1A < MIN_SPEED) OCR1A += 20; }
  if((ms-last_time) > 100) { //run every 0.1s
    last_time = ms;
    DRV_STATUS_t drv_status{0};
    drv_status.sr = driver.DRV_STATUS();
    Serial.print("0 ");
    Serial.print(drv_status.sg_result, DEC);
    Serial.print(" ");
    Serial.println(driver.cs2rms(drv_status.cs_actual), DEC);
the program used direct manipulation of the AVR timer peripheral, which is something that the STM32 doesn't have (the STM32 has timers but they're not the same as AVR timers.)
Port the sketch will requiring figuring out what the AVR timer code is doing, and figuring out how to do the same thing on the STM32. Not really a "beginner-friendly" task.
Right. I think I'll leave it then. Well thanks very much for the reply!
