Converting digital pin input to byte
I am working on a project where I have got a byte array (that should represent a 7 digit display output) and the 7 digit display pins are connected to my ESP8266 (with Arduino IDE).
What I’d like to do, is convert the digital pins 0~7 (8 in total) to a byte.
I’ve been using a boolean array to check wherether everything is working, it isn’t.
I am missing bits when I am checking what the output of the conversion is.
This is my code:
  //pinMode(0, OUTPUT); Lets the esp crash
  //pinMode(1, OUTPUT); Lets the esp crash
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  //pinMode(7, OUTPUT); Lets the esp crash
  digitalWrite(0,HIGH);
  digitalWrite(1,HIGH);
  digitalWrite(2,HIGH);
  digitalWrite(3,HIGH);
  digitalWrite(4,LOW);
  digitalWrite(5,LOW);
  digitalWrite(6,HIGH);
  digitalWrite(7,LOW);
  for(int i = 0; i < 8; i++)
    if(digitalRead(i) == 1){
      bitSet(inputByte, i);
    //bitWrite(inputByte, 9-i, inputBytes[i]);
  Serial.println("Converting: ");
  Serial.println(inputByte, BIN);
The Serial outputs:
Converting:
110101
What am I missing out here?
Maybe this post can help you out:
This is my code:
or at least a very small part of it.
Are you by any chance using Serial input or output in your program ? The reason that I ask is that pins 0 and 1 are used by the Serial interface.
UKHeliBob: or at least a very small part of it.
Yeah sorry, the forum was doing very annoying with editing my message. Fixed now
As I suspected, you are using pins 0 and 1 which are also used by the Serial interface. Use pins other than 0 and 1
You still have not posted your complete program so it is not obvious that you have set the pinMode()s of the pins correctly.
When using BIN with Serial.print() it does not print leading zeroes. Try printing 0 or 1 for each individual bit.
UKHeliBob: As I suspected, you are using pins 0 and 1 which are also used by the Serial interface. Use pins other than 0 and 1
On an unknown ESP8266 module (not ESP-01, that does not even have 8 io pins) ?
timkoers: I am working on a project where I have got a byte array (that should represent a 7 digit display output) and the 7 digit display pins are connected to my ESP8266 (with Arduino IDE).
Whandall:
That is correct, TX and RX are not digital pins 0 and 1. I am using the ESP-12F from Geekcreit.
UKHeliBob:
I didn’t know that the Serial.print() function cuts the leading zeroes. Is it doing the same with the ending zeroes?
timkoers: I didn't know that the Serial.print() function cuts the leading zeroes. Is it doing the same with the ending zeroes?
Of course not, only insignificant leading zeros are suppressed, no matter what base is choosen.
How many zeros in front would you expect when you execute Serial.print(1) ?
Whandall:
Zero haha
UKHeliBob:
Reading back on the topic, I figured out you are right. Calling digitalWrite(1, HIGH); is setting the TX line high.
I need to use D0 and D1, not 0 and 1.
The code that I currently have works perfectly!
byte pins[9] = {
  D0,
  D1,
  D2,
  D3,
  D4,
  D5,
  D6,
  D7,
  D8
  for (int i = 0; i < 8; i++)
    pinMode(pins[i], OUTPUT);
byte inputByte = B00000000;
  digitalWrite(D0, HIGH);
  digitalWrite(D1, HIGH);
  digitalWrite(D2, HIGH);
  digitalWrite(D3, HIGH);
  digitalWrite(D4, LOW);
  digitalWrite(D5, LOW);
  digitalWrite(D6, HIGH);
  digitalWrite(D7, LOW);
    if (digitalRead(pins[i]) == 1) {
      inputByte |= (1<<i);
Output is:
Converting:
1001111 (without the leading 0)
