Converting DS18B20 output to integer value
Was wondering how to convert the DS18B20 output to integer value. For use with the Guino graphvalue.
I think you just call the variable "int"
If you use the OneWire library, the zip file contains example code for the DS18B20 http://www.pjrc.com/teensy/td_libs_OneWire.html
Here is Arduino page for the OneWire library. Also with that example: http://playground.arduino.cc/Learning/OneWire
I'm having no problem getting the Thermometor to work. Its getting it to work with the guino gui that is giving me fits. Tells me its not an INT and gets an error.
Phil125: I'm having no problem getting the Thermometor to work. Its getting it to work with the guino gui that is giving me fits. Tells me its not an INT and gets an error.
The DS18B20's natural inclination is to deliver data to two decimal points.
If you declare data to be int, it will be an int. If you don't, it won't.
Klink is using DS18B20 with int and I guess his method is what you want.
