Converting ESP32-WROOM-32 to ESP-C3_mini
OK. So I have a program, working, on a ESP32_WROOM-32 board. And now that it's nearly ready I want to port it to an ESP32-C3-mini for size. It uses very few pins, as you can see below.
#include <FastLED.h>
#define NUM_LEDS 60  // Numbr of LEDs
#define DATA_PIN 4  // Incoming Data from BT
#define LED_TYPE NEOPIXEL
#define COLOUR_ORDER GRB
#define BRIGHTNESS 60
#define VOLTS 5
#define MAX_AMPS 500
int LED_SPEED = 10;  // LED Speed - varies with Faster/Slower
int SOUND_VOLUME;
char SOUND_PLAYING;
char LED_COLOUR = 'B'; //  LED Colour - varies Red/Blue/Green/White
char RUNNING = 'N';  //  Defines whether light strip/sounds/buzzes are currently running Y = Yes, B = Brake (finish cycle then stop), N = No
#include "BluetoothSerial.h"
#define LEDpin 2  // The pin to which the LED is connected
BluetoothSerial SerialBT;
char command;
CRGB leds[NUM_LEDS];
  { Serial.begin(115200);
    SerialBT.begin("LightBar");  // Bluetooth device name
    pinMode(LEDpin, OUTPUT);
    Serial.println("The device started, now you can pair it with Bluetooth!");
    FastLED.addLeds<LED_TYPE, DATA_PIN>(leds, NUM_LEDS);
    FastLED.setMaxPowerInVoltsAndMilliamps(VOLTS, MAX_AMPS);
    FastLED.setBrightness(BRIGHTNESS);
    FastLED.clear();
    FastLED.show();
  if (SerialBT.hasClient()) {
    digitalWrite(LEDpin, HIGH);  // Turn the LED on when connected
    digitalWrite(LEDpin, LOW);  // Turn the LED off when not connected
  // DATA RECEIVED DATA RECEIVED DATA RECEIVED DATA RECEIVED
  if (SerialBT.available()) {
    char receivedChar = SerialBT.read();
      Serial.println(receivedChar);
    if (receivedChar == 'T') {
      RUNNING = 'Y';
      Serial.println(RUNNING);
    if (receivedChar == 'O') {
      RUNNING = 'B';
    if (receivedChar == 'B') {
      LED_COLOUR = 'B';
    if (receivedChar == 'R') {
      LED_COLOUR = 'R';
    if (receivedChar == 'G') {
      LED_COLOUR = 'G';
    if (receivedChar == 'W') {
      LED_COLOUR = 'W';
    if (receivedChar == 'X') {
      LED_COLOUR = 'X';
    if (receivedChar == 'C') {
      SOUND_PLAYING = 'T';           // Play Tick Tock
    if (receivedChar == 'L') {
      SOUND_PLAYING = 'B';          // Play Bell
    if (receivedChar == 'Z') {
      SOUND_PLAYING = 'Z';          // Turn Off Sound
    if (receivedChar == '+') {
      Serial.println(LED_SPEED);
      int LEDSPEED = LED_SPEED - 1;
      LED_SPEED = LEDSPEED;
      Serial.println("+");
    if (receivedChar == '-') {
      int LEDSPEED = LED_SPEED + 1;
      Serial.println("-");
      LED_SPEED == LEDSPEED;
  // CYCLE CYCLE CYCLE CYCLE CYCLE CYCLE CYCLE CYCLE
  if (RUNNING == 'Y' || RUNNING == 'B') {
    Serial.println("CYCLE");
    if (RUNNING == 'B') {
      RUNNING = 'N';
    //      START - BLUE - BLUE - BLUE - BLUE
    if (LED_COLOUR == 'B') {
      for (int dot = 0; dot < NUM_LEDS; dot++) {
        leds[dot] = CRGB::Blue; // Blue LED
        FastLED.show();
        // clear this led for the next time around the loop
        leds[dot] = CRGB::Black;
        delay(LED_SPEED);
      Serial.println("Blue R");  //                                           PRINT "Blue R"
      for (int dot = NUM_LEDS - 1; dot >= 0; dot--)  {
        FastLED.show();
        leds[1] = CRGB::Black;
        delay(LED_SPEED);
      SerialBT.write(1);
      Serial.println("Flash 1");
      Serial.println("Blue L");  //                                           PRINT "Blue L"
    //      END - BLUE - BLUE - BLUE - BLUE
    //      START - WHITE - WHITE - WHITE - WHITE
    if (LED_COLOUR == 'W') {
        leds[dot] = CRGB::White; // White LEDs
        FastLED.show();
        delay(LED_SPEED);
      Serial.println("White R");  //                                           PRINT "White R"
        FastLED.show();
        delay(LED_SPEED);
        SerialBT.write(1);
        Serial.println("Flash 2");
      Serial.println("White L");  //                                           PRINT "White L"
    //        END - WHITE - WHITE - WHITE - WHITE
    //        START - RED - RED - RED - RED - RED
    if (LED_COLOUR == 'R') {
        leds[dot] = CRGB::Red; // Red LEDs
        FastLED.show();
        delay(LED_SPEED);
      Serial.println("Red R");  //                                           PRINT "Red R"
        FastLED.show();
        delay(LED_SPEED);
        SerialBT.write(1);
        Serial.println("Flash 3");
      Serial.println("Red L");  //                                           PRINT "Red L"
    //        END - RED - RED - RED - RED - RED
    //        START - GREEN - GREEN - GREEN - GREEN
    if (LED_COLOUR == 'G') {
        leds[dot] = CRGB::Green; // Green LEDs
        FastLED.show();
        delay(LED_SPEED);
      Serial.println("Green R");  //                                           PRINT "Green R"
        FastLED.show();
        delay(LED_SPEED);
      SerialBT.write(1);
      Serial.println("Flash 4");
      Serial.println("Green L");  //                                           PRINT "Green L"
    //         END - GREEN - GREEN - GREEN - GREEN
//        START - LBOff - LBOff - LBOff - LBOff
    if (LED_COLOUR == 'X') {
        leds[dot] = CRGB::Black; // Green LEDs
        FastLED.show();
      Serial.println("LBOff");  //
    //         END - LBOff - LBOff - LBOff - LBOff
My issue is that when I try to re-compile for the C3 I get a tonne of error messages.
I'll put them here, but I suspect there's one generic issue I'm missing.
Help? I've had, (and needed a lot of help here, but I'm clearly missing something.....
In file included from c:\Users\cex\Documents\Arduino\libraries\FastLED\src/FastLED.h:75,
                 from C:\Users\cex\Documents\Arduino\LearnStripBigC3\LearnStripBigC3.ino:1:
c:\Users\cex\Documents\Arduino\libraries\FastLED\src/fastspi.h:157:23: note: #pragma message: No hardware SPI pins defined.  All SPI access will default to bitbanged output
 #      pragma message "No hardware SPI pins defined.  All SPI access will default to bitbanged output"
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Temp\arduino\sketches\68E0B262AF9CB632D1443F83FF0C871A\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `.L0 ':
C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:713: undefined reference to `esp_spp_disconnect'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Temp\arduino\sketches\68E0B262AF9CB632D1443F83FF0C871A\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `_stop_bt':
C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:714: undefined reference to `esp_spp_deinit'
C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:189: undefined reference to `esp_spp_write'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:153: undefined reference to `esp_bt_gap_set_pin'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:650: undefined reference to `esp_bt_gap_register_callback'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Temp\arduino\sketches\68E0B262AF9CB632D1443F83FF0C871A\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `_init_bt':
C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:658: undefined reference to `esp_spp_register_callback'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:664: undefined reference to `esp_spp_init'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:686: undefined reference to `esp_bt_gap_set_security_param'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:691: undefined reference to `esp_bt_gap_set_cod'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Temp\arduino\sketches\68E0B262AF9CB632D1443F83FF0C871A\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `.LVL474':
C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:265: undefined reference to `esp_bt_gap_set_scan_mode'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Temp\arduino\sketches\68E0B262AF9CB632D1443F83FF0C871A\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `esp_spp_cb':
C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:271: undefined reference to `esp_spp_start_srv'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:283: undefined reference to `esp_spp_disconnect'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:364: undefined reference to `esp_spp_connect'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:391: undefined reference to `esp_spp_disconnect'
C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:126: undefined reference to `esp_bt_gap_resolve_eir_data'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Temp\arduino\sketches\68E0B262AF9CB632D1443F83FF0C871A\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `get_name_from_eir':
C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:130: undefined reference to `esp_bt_gap_resolve_eir_data'
C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:456: undefined reference to `esp_bt_gap_cancel_discovery'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Temp\arduino\sketches\68E0B262AF9CB632D1443F83FF0C871A\libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `esp_bt_gap_cb':
C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:458: undefined reference to `esp_spp_start_discovery'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:522: undefined reference to `esp_bt_gap_pin_reply'
c:/users/cex/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial\src/BluetoothSerial.cpp:538: undefined reference to `esp_bt_gap_ssp_confirm_reply'
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "BluetoothSerial.h"
  Used: C:\Users\cex\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\BluetoothSerial
  Not used: C:\Users\cex\Documents\Arduino\libraries\BluetoothSerial
exit status 1
Compilation error: exit status 1
FastLED won't work, but Adafruit_NeoPixel does
Thanks. Working on it now.
