converting feet to metres with decimal points
Hi all,
first time poster but long time reader and user
anyway i have a problem with math, im trying to convert feet to metres on a button press. at the minute i have an array counting from 0.0ft to 10.6 ft and the corresponding metre code in a switch case like the example, the switch case points to a function under as void one(); (see the example).
now the obvious problem straight away is 12 inches times 10 feet = a lot of switch cases and a bloated code. but does make it easy writing to sd card and lcd screen,
I tried several ways to count up but none work, i dont know enough about arrays and bits to even start a code, i have tried examples and studying the process of it but it just doesnt click?
I know there is a simple way to count up through this range without hundreds of lines of code. can anybody help me with this? i cant post my code as it keeps changing forms and its way to long but an example of my switch case is as follows
//example
switch (count){ //my generic switch code, counts up with button press
case 1:
one(); //points to below example shortened
//void one as example, excuse the mistakes its from memory and does work
void one(){
lcd.clear();
lcd.setCursor(0,0);
lcd.write ("0.1ft or 0.03 mtr);
myfile.(stat.txt,READ_WRITE);
myfile.write (“0.01ft or 0.03mtr”)
myfile.close();
i have hundreds of these, can you help! :slight_smile:
...im trying to convert feet to metres on a button press...
In what increments? 0.1 feet per button press?
hey, thanks for the reply, yes, my void functions are 0.1,0.2,0.3 etcand the relevant conversion for metres,
im having difficulty with the converting stage.
so for example;
inch = 1; feet = inch times 12 metre = 3.28 feet //i have no idea if this idea would work, obviously implemeted correctly?
if (upbutton pressed == high){ count up 1 write to lcd }
if (downbuttonpressed == high){ count down 1 write to lcd }
if (enterbuttonpressed == high){ write to sd card the conversion
am i missing a really simple statement?
i also have a rtc through ic2 to write the datestamp
meters = feet / 3.28
Have you noticed any consistent mathematical relationship as you increment through the values?
but how does that count up?
metre =feet /3.28
but…
how do i use that statement to produce results as well as convert between the two in a button press? i thought seeing as its climbing through an array of sorts, i would need seperate lcd prints and sd writes?
i currently have,
turn on,
feet or metre //buttonpress
count up and show on lcd //buttonpress
count down and show on lcd //buttonpress
press enter-save to sd and show on lcd //buttonpress
id like a variable to be able to use anywhere like
int magical = 0;
magical = count;
count = inch;
inch = 1.00;
feet = inch / 12;
metre / feet/3.28
insert magical conversion code here
count up in metres or feet
ive been on this for ages and cannot find a soluton within my knowledge and heavy googling just helped confuse me more on bits and thisnumber++thatnumber,++this number?!?!?!?
im not an ignorant person and i love a challenge but i can not figure this out!
phillmybuttons: ...counting from 0.0ft to 10.6 ft ... //example switch (count){ //my generic switch code, counts up with button press
When count = 0, feet = 0. When count = 1, feet = 0.1. When count = 2, feet = 0.2. Time for our first expression...
float feet;
void loop( void )
  feet = count / 10.0;
Whenever you change count, recalculate feet using the expression above.
Next, calculcate meters...
float meters;
void loop( void )
  meters = feet / 3.28;
Because meters depends on feet (which depends on count) the expressions have to be performed in order...
void loop( void )
  // Update count when the button is pressed
At this point, you will need to format the output; create the string “0.1ft or 0.03 mtr” # where the “0.1” is replaced with feet converted to a string and “0.03” is meters converted to a string.
# Note: “mtr” is not the correct abbreviation for meter.
thanks for the detailed reply, i wish i understood it :/
so if i have a float, all i seem to be doing with the count number is dividing it?
and do i convert the "string" to an val? or dec, so lcd.write ("feet,VAL,metre,VAL1); ?
it seems i cant get around the math behind this? or the logic of how n it works,
i know this seems a bit of a pain especially since you gave such a detailed answer but would you be able to explain it? briefly is fine, I just dont how dividing it so many times yields a conversion? thankyou :)
its cool if you cant, it its late to be fair,thanks
phillmybuttons: thanks for the detailed reply, i wish i understood it :/
Maybe it will make sense in the morning.
Yes. Each count increments by one. Dividing that by ten gives you feet. Meters = feet / 3.28
No. Split your lcd.writes See the example in the code block below.
// lcd example
// clear the screen and position cursor
lcd.write("Ft ");    // write the first part
lcd.write(feet);     // the variable feet found with count / 10
lcd.write(" M ");
lcd.write(meters);   // meters = feet / 3.28
Hope it helps.
