Converting float into a character
Hi arduino members,
I have a few problem with my code. I don't know what is the problem but the value of my gas sensor which is declared and already calibrated doesnt converted into a character. So for you not to be confused because i am, here is my sample code:
 sensorValue = analogRead(A0);
  float gas = MQGetGasPercentage(MQRead(MQ_PIN)/Ro,GAS_LPG);
  float smoke= MQGetGasPercentage(MQRead(MQ_PIN)/Ro,GAS_SMOKE);
  float co = MQGetGasPercentage(MQRead(MQ_PIN)/Ro,GAS_CO);
 if(gas,smoke,co != 0){
 Serial.print("Gas detected");
 char sensor[200];
 sprintf(sensor,"gas = %f smoke = %f co = %f",gas,smoke,co);
 Serial.println("SENDING MESSAGE! ...");
 Serial.println(sensor);
this is problem i've encountered, pls see the output below.
 GSMTEST.sendSMS(PHONE_NUMBER, sensor);
  //send message
  Serial.print("LPG:");
  Serial.print(gas);
  Serial.print( "ppm" );
  Serial.print("    ");
  Serial.print("CO:");
  Serial.print(co);
  Serial.print("    ");
  Serial.print("SMOKE:");
  Serial.print(smoke);
  Serial.print("\n");
The output that i've encounter is like this,
Output: gas = ? smoke = ? co = ?
Pls help me
if(gas,smoke,co != 0)Tell us about that line.
You do know that by default, %f is disabled for the 8 bitters?
Use dtostrf instead
It is logically says that
if(gas || smoke || co !=0){
//Codes
Im sorry but i dont know about that %f with 8 bit something.
Use dtostrf instead
I tried that dtostrf thing, but it the arduino IDE doesnt recognize it, is there anything i can do with it? or something to declare in global for that decimal to string(dtostrf) will work?
Thanks so much for quick response. :slight_smile:
Code: [Select]
//Codes
It does?
That surprises me greatly.
It does?
yes. Probably it works for awhile but i'll change it. But coding for me as a first timer huh? :confused:
Is there anything that i can do?
You can try dtostrf again
Im sorry, but can you please give me an example? sorry for being noob. The link you give to me seems to be out of this world for me. Can you relate it to my codes?
Thanks :slight_smile:
Put "dtostrf Arduino example" into Google, and make an offering to a deity of your choice.
is the same as
if(co != 0)
Example:
  Serial.begin(250000);
  if (1, 1, 1, 1, 1, 1, 1, 0) {
    Serial.println(F("True"));
    Serial.println(F("False"));
void loop() {}
False
and you get a bunch of warnings for free
somewhere\CommaOp.ino:3:10: warning: left operand of comma operator has no effect [-Wunused-value]
somewhere\CommaOp.ino:3:13: warning: right operand of comma operator has no effect [-Wunused-value]
somewhere\CommaOp.ino:3:16: warning: right operand of comma operator has no effect [-Wunused-value]
somewhere\CommaOp.ino:3:19: warning: right operand of comma operator has no effect [-Wunused-value]
somewhere\CommaOp.ino:3:22: warning: right operand of comma operator has no effect [-Wunused-value]
somewhere\CommaOp.ino:3:25: warning: right operand of comma operator has no effect [-Wunused-value]
somewhere\CommaOp.ino:3:28: warning: right operand of comma operator has no effect [-Wunused-value]
I'm curious as to what you'd hope to glean about your problem by reading my forum profile.
Interesting, I am just exploring about this forum because im new to this thing. Glad i found a better place about my problem. But still im searching for luck,
is dtostrf can have many float variable? like this thing
char sensor[200];
 dtostrf(gas,smoke,co,1,2,sensor);
and i've got an error of
invalid conversion from 'int' to 'char*' [-fpermissive]
thanks
No. One conversion per call.
Hi AWOL,
Thank you so much! I appreciate ur help although i feel you look some kind of irritated or what. but thanks anyways! :wink:
and for Whandall, i'll do my very best to fix my code. thanks!
Your usage of dtostrf is irritating, as AWOL gave you a link to the documentation of the function.
Well, stop. Programming is NOT about luck. It involves logic and the ability to read documentation and TRY things.
danArd:
ur help
I wasn't irritated, but I am now.
The handy thing about the World Wide Web is that it comes with handy search tools, and when someone gives you pretty specific search terms, "Bingo!", things happen.
Or maybe not.
OK further hint, sprintf doesn't support %f, but it does support %s.
Or, go lightweight, don't use sprintf, use strcat instead.
Hey guys, i already solved this. That's why im thanking AWOL for this
Sorry for that :slight_smile: Chill and wanna drink some beer?
so here sharing my code if ever there's other people here that have same cases with me
if(sensorValue != 0){
         int y=0;
         while(y != 3){
         static char sensor[10];
         static char sensor1[10];
         static char sensor2[10];
         dtostrf(gas,1,2,sensor);
         dtostrf(smoke,1,2,sensor1);
         dtostrf(co,1,2,sensor2);
         char finalRead[50];
         sprintf(finalRead,"Gas= %s ppm, smoke = %s ppm, co = %s ppm",sensor,sensor1,sensor2);
         Serial.println(finalRead);
         GSMTEST.sendSMS(PHONE_NUMBER,  finalRead );
         tone(BUZZER,1000);
         delay(3000);
         noTone(BUZZER);
         y++;
  //send message
Thanks everyone and have a nice day ahead!
i wanna
The irritation just keeps growing.
I think you need to drink beer then. toast! :slight_smile:
Why “static”?
