Converting Float to Int
Hey forum,
Im building a gps reciever. I allready recieve coordinates, but I want to display these coordinates on an PCD8544 lcd screen. I recieve the coordinates as a float, example:
flat=51.96512;
This coordinate is the type I want to display on the PCD8544. I have tried to make the float an int bij simply multiplying it bij 100,000. This obviously doesn't work, because the number becomes 5,100,000. Can somebody explain how I can convert an 5 decimal float like: 51.96512 to an int like: 5196512 It is no problem to display 5196512 on the PCD8544, but I cant convert the 51.96512 to 5196512.
Any help is welcome.
Regards,
Leo
5196512
leovanasch: Can somebody explain how I can convert an 5 decimal float like: 51.96512 to an int like: 5196512
5,196,512 can't be converted to an int because that well over the maximum amount that can be stored an int.
Try converting it to a long.
Thanks for your reply!
tried to convert it:
flat=51.96512; long flatlong=long(flat)
now it puts out 51
if i do the following:
flat=51.96512; long flatlong=long(flat*100000);
it puts out 19168, which doesnt make any sense
This works fine, incrementing properly.
float original = 51.123456;
long converted;
  // initialize serial communication at 9600 bits per second:
  converted = original * 100000;
  Serial.println(converted);
  delay (2000);
  converted++;
Try 100000UL.
Mark
leovanasch: if i do the following:
In your example you don't give 'flat' a type . the type should be float than it works fine
Ok i've fixed it!
I'm processing the coordinate as below:
flat=51.96512; long flatlong; flatlong=flat*100000; latProces(flatlong,0,5);
the latProces is declared as following:
void latProces(long d, int x, int y)
this is the function I use to process the coordinate to display it on the PCD8544. before, the variable d was declared as an int and not as a long, I changed this and now it works, stupid mistake.
astrofrostbyte: In your example you don't give 'flat' a type . the type should be float than it works fine
flat was allready declared globally as a float
and of course, thank you all very much!
Can I ask the question how you got a float in the first place? If it came as part of an ASCII message, it never was a float to begin with.
AWOL:
the code is part of the based on an example from the tinygps library:
http://arduiniana.org/libraries/tinygps/
The following piece of code gives the positions:
gps.f_get_position(&flat, &flon, &age);
But TinyGPS reads NMEA sentences - they're ASCII. If it never was a float, there's little point converting to and fro.
My code is based on the example, and now it works so thats fine for me. And to display it on an PCD8544 i need to convert it
