I am writing code to perform calculations on the data stored in an RFID tag memory every time its scanned. the tag stores bytes and i would like to carry out the calculations in int data type. any help would be greatly appreciated. thanks in advance
thanks for the reply , but actually the way i see it is like we save data to the byte array as a string. is there a way i could save an integer like data to the string or its already an integer even when its added in quotations like for strings.
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10 /* Slave Select Pin */
#define RST_PIN 9 /* Reset Pin */
/* Create an instance of MFRC522 */
MFRC522 mfrc522(SS_PIN, RST_PIN);
/* Create an instance of MIFARE_Key */
MFRC522::MIFARE_Key key;
int blockNum = 2;
byte blockDataAmount[5] = {"10000"}; //this is the amount of money stored on the card initially
byte blockDataPrice [5] = {"1000"};//this is the price per unit cut
byte blockDataBalance[5] = blockDataAmount[5] - blockDataPrice [5] ; //and this is the amount of money balance left after the price per unit cut is subtracted from the initial amount above
// this balance is what is to be stored to the tag after scanning
MFRC522::StatusCode status;
/* Initialize serial communications with the PC */
/* Initialize SPI bus */
SPI.begin();
/* Initialize MFRC522 Module */
mfrc522.PCD_Init();
Serial.println("Scan a MIFARE 1K Tag to write data...");
/* Prepare the key for authentication */
/* All keys are set to FFFFFFFFFFFFh at chip delivery from the factory */
for (byte i = 0; i < 6; i++)
key.keyByte[i] = 0xFF;
/* Look for new cards */
/* Reset the loop if no new card is present on RC522 Reader */
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
/* Select one of the cards */
if ( ! mfrc522.PICC_ReadCardSerial())
return;
/* Call 'WriteDataToBlock' function, which will write data to the block */
Serial.print("\n");
Serial.println("Writing to Data Block...");
WriteDataToBlock(blockNum, blockDataBalance);
void WriteDataToBlock(int blockNum, byte blockDataBalance[])
/* Authenticating the desired data block for write access using Key A */
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, blockNum, &key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK)
Serial.print("Authentication failed for Write: ");
Serial.println(mfrc522.GetStatusCodeName(status));
return;
Serial.println("Authentication success");
/* Write data to the block */
status = mfrc522.MIFARE_Write(blockNum, blockDataBalance, 16);
Serial.print("Writing to Block failed: ");
return;
Serial.println("Data was written into Block successfully");
I still don't know what you are trying to do apart from write to an RFID card
Neither of these declarations makes sense and I don't see where in the code you read from the card
i would like the first one to store the initial amount on the tag and the second one to store the price of an item that shall bve deducted from the card amount every time a tag is scanned.
I am not reading from the card in this particular code nut in a different one aside
#include <SPI.h>
int blockNum = 2;
byte bufferLen = 8;
byte readBlockData[8];
SPI.begin();
mfrc522.PCD_Init();
//Serial.println("Scan a MIFARE 1K Tag to write data...");
Serial.println("Scan a MIFARE 1K Tag to read data...");
return;
return;
/* Read data from the same block */
Serial.print("\n");
Serial.println("Reading from Data Block...");
ReadDataFromBlock(blockNum, readBlockData);
/* Print the data read from block */
Serial.print("\n");
Serial.print("Data in Block:");
Serial.print(blockNum);
Serial.print(" --> ");
for (int j = 0 ; j < 5 ; j++)
Serial.write(readBlockData[j]);
Serial.print("\n");
void ReadDataFromBlock(int blockNum, byte readBlockData[])
/* Authenticating the desired data block for Read access using Key A */
byte status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, blockNum, &key, &(mfrc522.uid));
Serial.print("Authentication failed for Read: ");
return;
/* Reading data from the Block */
status = mfrc522.MIFARE_Read(blockNum, readBlockData, &bufferLen);
Serial.print("Reading failed: ");
return;
Serial.println("Block was read successfully");
