Converting from Serial moniter to LCD screen
I'm trying to display the text I write into the serial monitor onto the LCD screen. I'm trying to perform string character analysis through the serial monitor and then see the text on LCD screen. Right now only random letters are being shown on the LCD while its working through string analysis. The code I've got right now is:
// Import the Liquid Crystal library
#include<LiquidCrystal.h>;
//Initialise the LCD with the arduino. LiquidCrystal(rs, enable, d4, d5, d6, d7)
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  lcd.begin(16, 2);
    // Print these words to my LCD screen
  lcd.print("HELLO WORLD!");
 while (!Serial) {
 ; // wait for serial port to connect.
 // send an introduction:
 Serial.println("send any byte and I'll tell you everything I can about it");
 // get any incoming bytes:
 if (Serial.available() > 0) {
int thisChar = Serial.read();
 // say what was sent:
    if (isUpperCase(thisChar)) {  // tests if thisChar is an upper case letter
  Serial.println("The character is upper case");
else {
  Serial.println("The character is not upper case");
   if (isAlphaNumeric(thisChar)) { // tests if thisChar isa letter or a number
  Serial.println("The character is alphanumeric");
else {
  Serial.println("The character is not alphanumeric");
   if (isAlpha(thisChar)) {  // tests if thisChar is a letter
  Serial.println("The character is a letter");
else {
  Serial.println("The character is not a letter");
   if (isAscii(thisChar)) {  // tests if thisChar is an Ascii character
  Serial.println("The character is Ascii");
else {
  Serial.println("The character is not Ascii");
   if (isWhitespace(thisChar)) { // tests if thisChar is a white space
  Serial.println("The character is a white space");
else {
  Serial.println("The character is not a white space");
   if (isControl(thisChar)) {  // tests if thisChar is a control character
  Serial.println("The character is a control character");
else {
  Serial.println("The character is not a control character");
  if (isDigit(thisChar)) {  // tests if thisChar is a digit
  Serial.println("The character is a number");
else {
  Serial.println("The character is not a number");
   if (isGraph(thisChar)) {  // tests if thisChar is a graph
  Serial.println("The character is a printable charater thats not whitespace");
else {
  Serial.println("The character is not a printabe character thats not whitespace");
   if (isLowerCase(thisChar)) {  // tests if thisChar is a lower case letter
  Serial.println("The character is lower case");
else {
  Serial.println("The character is not lower case");
   if (isPrintable(thisChar)) {  // tests if thisChar is printable char
  Serial.println("The character is printable");
else {
  Serial.println("The character is not printable");
   if (isPunct(thisChar)) {  // tests if thisChar is a punctuation character
  Serial.println("The character is a punctuation");
else {
  Serial.println("The character is not a punctuation");
   if (isSpace(thisChar)) {  // tests if thisChar is a white-space character
  Serial.println("The character is white-space");
else {
  Serial.println("The character is not white-space");
   if (isHexadecimalDigit(thisChar)) { // tests if thisChar is an hexadecimal digit
  Serial.println("The character is an hexadecimal digit");
else {
  Serial.println("The character is not an hexadecimal digit");
 Serial.print("You sent me: \'");
 Serial.write(thisChar);
 Serial.print("\' ASCII Value: ");
 Serial.println(thisChar);
 // add some space and ask for another byte:
 Serial.println("Give me another byte:");
   if (Serial.available()) {
     //wait for entire message to arrive
     delay(600);
     //clear the screen
     lcd.clear();
     lcd.write(Serial.read());
Sigh.
Edit your post and use code tags. You missed how to post code when you read the things how to get the most out of this forum.
You seem to be clearing the LCD before each character is read. Why? Also no cursor positioning is being used. And finally, are you trying to display the line ending, CR/LF coming from your serial reading?
Paul
