Hi all! I have an RFID reader outputting a string of hex digits that are printed to the Serial monitor (as hex digits). I want them to be decoded to be their corresponding ASCII characters instead. For example, I will get something like epc[54 65 73 74 4D 63 4B 65 6C 6C 61 72] (running great) and that will be printed to the serial monitor. What I would like to do is take that hex code and translate it to [running great] and print that.
Note: I am using the SparkFun Simultaneous RFID reader (and some modified code from its examples)
My code (printing the hex digits):
#include <SoftwareSerial.h>
SoftwareSerial softSerial(2, 3);
#include "SparkFun_UHF_RFID_Reader.h"
RFID nano;
#define buzzer 9
#define buzzergnd 10
pinMode(buzzer, OUTPUT);
pinMode(buzzergnd, OUTPUT);
digitalWrite(buzzergnd, LOW);
while(!Serial);
if (setupNano(38400) == false) //Configure nano to run at 38400bps
Serial.println(F("Module failed to respond. Please check wiring."));
while (1); //Freeze!
nano.setRegion(REGION_NORTHAMERICA);
nano.setReadPower(2700);
Serial.println("Press a key to begin scanning for tags");
while(!Serial.available());
Serial.read();
nano.startReading();
if(nano.check() == true){
byte responseType = nano.parseResponse();
if(responseType == RESPONSE_IS_TAGFOUND){
Serial.print(F(" epc["));
byte tagEPCBytes = nano.getTagEPCBytes();
for(byte x = 0 ; x< tagEPCBytes ; x++){
if(nano.msg[31 + x] < 0x10) Serial.print("0");
Serial.print(nano.msg[31 + x], HEX);
Serial.print((" "));
Serial.print("]");
boolean setupNano(long baudRate)
nano.begin(softSerial); //Tell the library to communicate over software serial port
//Test to see if we are already connected to a module
//This would be the case if the Arduino has been reprogrammed and the module has stayed powered
softSerial.begin(baudRate); //For this test, assume module is already at our desired baud rate
while (softSerial.isListening() == false); //Wait for port to open
//About 200ms from power on the module will send its firmware version at 115200. We need to ignore this.
while (softSerial.available()) softSerial.read();
nano.getVersion();
if (nano.msg[0] == ERROR_WRONG_OPCODE_RESPONSE)
//This happens if the baud rate is correct but the module is doing a ccontinuous read
nano.stopReading();
Serial.println(F("Module continuously reading. Asking it to stop..."));
delay(1500);
//The module did not respond so assume it's just been powered on and communicating at 115200bps
softSerial.begin(115200); //Start software serial at 115200
nano.setBaud(baudRate); //Tell the module to go to the chosen baud rate. Ignore the response msg
softSerial.begin(baudRate); //Start the software serial port, this time at user's chosen baud rate
delay(250);
//Test the connection
nano.getVersion();
if (nano.msg[0] != ALL_GOOD) return (false); //Something is not right
//The M6E has these settings no matter what
nano.setTagProtocol(); //Set protocol to GEN2
nano.setAntennaPort(); //Set TX/RX antenna ports to 1
return (true); //We are ready to rock
