Converting int variable in hex
Hello buddies,
I have to implement a soft starter in my AC/AC converter driver. The code that I did is above.
#define F_CPU 1000000UL  // variavel de frequencia de clock para funcao delay
#include <avr/io.h>
#include <avr/interrupt.h>
#include <stdio.h>
#include <util/delay.h>
int i=0;
int k=0;
int j=0;
int ganho = 0;
int soft = 1;
int ciclo = 0;
int ALTO;
int BAIXO;
void ataque() {
	i++;
	if (i>3) {
	PORTG = 0x1;
	_delay_us(10);
	PORTG = 0x0;
	TCCR1B = 0x8;
	i=0;
void ataque1() {
	k++;
	if (k>3) {
	PORTG = 0x2;
	_delay_us(10);
	PORTG = 0x0;
	TCCR3B = 0x8;
	k=0;
void ataque2() {
	j++;
	if (j>3) {
	PORTG = 0x4;
	_delay_us(10);
	PORTG = 0x0;
	TCCR4B = 0x8;
	j=0;
void conversao() {
	PORTC = 0x0;
	_delay_us(2);
	PORTC = 0x2;
	_delay_us(10);
	ALTO = PINB;
	BAIXO = PINA;
void fasea() {
	if (soft == 1) {
		OCR1A = 0x3ff - (0x78*ganho);
		TCCR1B = 0x9; // inicia o timer da fase A
		ciclo++;
		if (ciclo == 10) {
			ganho++;
			ciclo = 0;
		conversao();
		if (ALTO > OCR1AH) {
			if (BAIXO > OCR1AL) {
			soft = 0;
	else {
		conversao();
		OCR1AH = ALTO;
		OCR1AL = BAIXO;
	OCR3A = OCR1A;
	OCR4A = OCR1A;
ISR(INT0_vect)
	fasea();
ISR(INT1_vect)
	TCCR3B = 0x9; // inicia o timer da fase B
ISR(INT2_vect) {
	TCCR4B = 0x9; // inicia o timer da fase C
ISR(TIMER1_COMPA_vect) {
	ataque();
ISR(TIMER3_COMPA_vect) {
	ataque1();
ISR(TIMER4_COMPA_vect) {
	ataque2();
int main(void)
	sei();
	EICRA = 0x15; // habilita as interrupções 0 1 e 2 por borda
	EIMSK = 0x7; // habilita interrupção externa 0 1 e 2
	DDRB = 0x0;
	DDRG = 0x07; // PG0 PG1 PG2 definidas como saída
	DDRC = 0x2; // PC1 definida como saida
	TCCR1A = 0x0; // configuracoes dos timers
	TCCR1B = 0x8;
	TCCR1C = 0x0;
	TCCR3A = 0x0;
	TCCR3B = 0x8;
	TCCR3C = 0x0;
	TCCR4A = 0x0;
	TCCR4B = 0x8;
	TCCR4C = 0x0;
	TIMSK1 = 0x2;
	TIMSK3 = 0x2;
	TIMSK4 = 0x2; // fim das configuracoes
	PORTC = 0x2;
    while(1)
As you can see, the drivers starts in soft starter condition. The OCRxA is set to maximum ADC value (0x3FF) and keeps decreasing after 5 cicles of AC Source, and gets out of soft starter when ADC value is bigger than the decreasing value.
When I tried to simulate it, it didn’t work as I supposed. The comparation between the decreasing variable and ADC value isn’t working well.
Before someone asks why i’m not using atmega adc converter, is because i couldn’t use the ADC in C programmation (i need to generate a .hex to simulate at Proteus, so I can’t use Arduino Compiler).
So, I wanna know how can get ALTO and BAIXO values (two 8 bits variables) and make it a 16 bits variable to make a better condition?
int ALTOandBAIXO = ALTO<<8 ;
ALTOandBAIXO += BAIXO;
You mean can’t use analogread? Try something like this:
ADCSRA |= (1<<ADSC); // do single conversion
// wait for conversion done, ADIF flag active
while(!(ADCSRA & 0x10));
ADC_temp = ADCL; // read out ADCL register
ADC_temp += (ADCH << 8); // read out ADCH register
I still don't understand why you don't use a board...
If it is only a simulation you'll be running and you have a board, why not wire up some 555 to get your AC cycles and a potmeter for your analog reading and ACTUALLY test the firmware, instead of trusting simulation software?
Hey man I changed it, but the program still don’t enter in if condition to get off soft starter.
the condition is ALTOandBAIXO > OCR1A
#include <avr/io.h>
#include <stdio.h>
int i=0;
int k=0;
int j=0;
int ganho = 0;
int soft = 1;
int ciclo = 0;
int ALTO;
int BAIXO;
int ALTOandBAIXO;
void ataque() {
	i++;
	if (i>3) {
	PORTG = 0x1;
	_delay_us(10);
	PORTG = 0x0;
	TCCR1B = 0x8;
	i=0;
void ataque1() {
	k++;
	if (k>3) {
	PORTG = 0x2;
	_delay_us(10);
	PORTG = 0x0;
	TCCR3B = 0x8;
	k=0;
void ataque2() {
	j++;
	if (j>3) {
	PORTG = 0x4;
	_delay_us(10);
	PORTG = 0x0;
	TCCR4B = 0x8;
	j=0;
void conversao() {
	PORTC = 0x0;
	_delay_us(2);
	PORTC = 0x2;
	_delay_us(10);
	ALTO = PINB;
	BAIXO = PINA;
void fasea() {
	conversao();
	if (soft == 1) {
		ciclo++;
		if (ciclo == 10) {
			ganho++;
			ciclo = 0;
		ALTOandBAIXO = ALTO<<8;
		if (ALTOandBAIXO > OCR1A) {
			soft = 0;
	else {
		OCR1AH = ALTO;
		OCR1AL = BAIXO;
	OCR3A = OCR1A;
	OCR4A = OCR1A;
ISR(INT0_vect)
	fasea();
ISR(INT1_vect)
ISR(INT2_vect) {
	ataque();
	ataque1();
	ataque2();
int main(void)
	sei();
	DDRB = 0x0;
	TCCR1B = 0x8;
	TCCR1C = 0x0;
	TCCR3A = 0x0;
	TCCR3B = 0x8;
	TCCR3C = 0x0;
	TCCR4A = 0x0;
	TCCR4B = 0x8;
	TCCR4C = 0x0;
	TIMSK1 = 0x2;
	TIMSK3 = 0x2;
	PORTC = 0x2;
    while(1)
bubulindo:
It's a project for university and it must have a software simulation.
