system
September 20, 2014, 4:44pm
1
So, I got this sketch for reading RFID tags, printing the output to the serial port and it works fine .
Here is the part of the code that does the reading to throw it on the port:
Serial.println("Card Number:");
Serial.print(rfid.serNum[0]);
Serial.print(", ");
Serial.print(rfid.serNum[1]);
Serial.print(", ");
Serial.print(rfid.serNum[2]);
Serial.print(", ");
Serial.print(rfid.serNum[3]);
Serial.print(", ");
Serial.print(rfid.serNum[4]);
Serial.println(" ");
The output is something like 245, 220, 58, 230, 245
My question is whether and, if yes, how it is possible to grab all the 5 elements of this array and put it on a character string. The purpose of this conversion is to further throw it on a SQL query to check if this "serial number" is registered in the database. Seems like the type of rfid.serNum is a unsigned char, as I saw it in the library:
unsigned char serNum[5];
I appreciate any help!
I use sprintf() to convert several variables into a character string, formatted just about any way one likes.
Some examples at sprintf | Liudr's Blog
system
September 20, 2014, 6:02pm
3
jremington:
Some examples at sprintf | LiuDr Electronic Solutions LLC Official Blog
Thanks for this tip, but how should I use it? I tried something like
char cardCode[16];
sprintf(cardCode, %s%s%s%s%s, rfid.serNum[0], rfid.serNum[1], rfid.serNum[2], rfid.serNum[3], rfid.serNum[4]);
and it gives me an error:
RFID:50: error: expected primary-expression before '%' token
RFID:50: error: 's' was not declared in this scope
:0
potew:
jremington:
char cardCode[16];
*RFID:50: error: expected primary-expression before '%' token*
*RFID:50: error: 's' was not declared in this scope*
enclose the format string in quotes. Did you even see the samples?
system
September 20, 2014, 7:43pm
5
pepe :
The char array supplied to receive the string must be large enough.
Five numbers of three figures, plus four comas, plus one ending nul character give a length of 5x3+4+1=20 .
The code should be :
char cardCode[20];
sprintf(cardCode, "%u,%u,%u,%u,%u", rfid.serNum[0], rfid.serNum[1], rfid.serNum[2], rfid.serNum[3], rfid.serNum[4]);
I understand what you did, but I aint including the commas for the final variable. Thanks for the tip
RobvdVeer:
:0
No, and where can I get those samples?
Putting them into quotes gave no compilation errors this time... thanks, guys!!
If you had taken the time to read BOTH lines of reply #1 , you would have seen the samples.
system
September 20, 2014, 8:51pm
7
jremington:
I really haven't noticed the link on your first reply. My mistake
system
September 21, 2014, 3:52pm
8
pepe :
If you don't include separators such as comas, be careful not to get confusing results.
For instance, how can one make a difference between { 12, 3, 4, 5, 67 } and { 1, 234, 5, 6, 7 }, since the result would be "1234567" in both cases ?
I also thought on that issue. The solution I found (on the link jremington posted) is to write "%003u%003u....." in order to add one or two zeroes whenever the number is smaller than 100, while it reserves the 3-digit limit (:
Thanks again, if it weren't for your help, I'll be stucked until now
mmpk
October 12, 2017, 8:03pm
9
HI
if i want to use the same concept on client object of WiFiClient library of MKR1000 how do i proceed. since WiFiClient has no member named sprintf?
sprintf() is standard C/C++.
