Converting ints into byte array
I’m working on a project were i want integers to go into a byte array.
I’m using a MAX7219 led matrix to display these integers.
#include "LedControl.h"
LedControl lc = LedControl(12, 11, 10, 1);
const int buttonPin = 2;
const int delayTime = 400;
int buttonState = 0;
float v1 = 1;
float v2 = 1;
float v3 = 1;
int row1[] ={0,0,0,0,1,1,0,0};
byte ledM[] =
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B  v1 v2 v3,
  B00000000
void pLedM()
  for (int i = 0; i < 8; i++)
    lc.setRow(0, i, ledM[i]);
  lc.shutdown(0, false);
  lc.setIntensity(0, 2);
  lc.clearDisplay(0);
  pinMode(buttonPin, INPUT);
  if (buttonState == HIGH) {
    pir1 = 1;
    pir1 = 0;
int row1[2] = {1};
now i want so every variable has to be responsible for one led on the matrix.
Your requirements are not clear; please try to explain again. I see a byte array but I don’t really see which integer you’re talking about.
Further
byte ledM[] =
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B  v1 v2 v3, <----------------- What is this
  B00000000
Please explain the line above; what do you want to achieve?
  int row1[2] = {1};
This more than likely does not do what you think it does. It creates a new variable row1 with 2 elements and initializes the first element with the value 1. This new variable hides your global row1 array.
If you want to assign a value to the third element in the global row1 array, use
  row1[2] = 1;
