Converting Log to Linear for resistors?
I've hacked apart an old joystick, and have connected the 2 variable resistors inside to my Uno. The resistors are both 120K, but upon reading their values in the serial window, they change much more when I push the joystick forward than when I push it back. I assume this would be because the resistors are not linear. If they are logarithmic, does anyone know how I can map the values from a logarithmic resistor to a linear output?
I'm assuming you've connected the center wiper terminal of each joystick to an analog input? Is there a way you can verify with a DMM whether this wiper resistance is or is not logarithmic.
You can always pass the raw analog value through an inverse-logarithmic function (the exp() or pow() functions would be a place to start) though this will require computation with real numbers and is considered "time consuming" relative to other things the microcontroller does.
-- The Rugged Motor Driver: two H-bridges, more power than an L298, fully protected
Yea, I've connected to the central terminal. To get the inverse logarithmic function, I would have to first find the normal logarithmic function, by taking samples from the resistor and plotting them? Is there any other way that isn't so much work?
see:- http://www.geofex.com/article_folders/potsecrets/potscret.htm
