The project that I'm working on, the MPR121 capacitive touch sensing keyboard connected with a 8051 microcontroller, my first intention when I started implementing the project was to measure the capacitance on the touched electrode, reading the datasheet I learned that I can get the capacitance value from the filter data later on I figured that the value I'm getting from filter data is reverse proportional with the capacitance
Image below shows the relation between capacitance and the voltage
Image below shows the value range 0-1024 that we can get from the filter data and shows that the value is inverse proportional with the capacitance enter image description here
I've configured 0x5c and 0x5d register so that charge current I is 16 mikroA and the charge time T is 0.5 mikroS, I'm getting values of filter data in range from 0-600 does this mean that the capacitance is calculated as below..
C=(IT)/V=(160.5)/(0-1024) ?
Thank you!
