The declaration is a function pointer named canEnter.
try re declaring it like the code below, might help.
Menu.h - Library for creating nested Menus with callback functions
Original Author: CWAL
License: Just leave this header, do anything else with it you want
#ifndef Menu_h
#define Menu_h
//#include "WProgram.h"
//This is for arduino 0022,23 - 1.0 compatibility.
#if defined(ARDUINO) && ARDUINO >= 100
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
//Add these lines
class Menu;
typedef boolean ( *EnterFunc )( Menu& );
class Menu
private:
Menu * parent;//Parent Menu, NULL if this is the top
Menu * child;//First Child Menu, NULL if no children
Menu * sibling;//Next Sibling Menu, NULL if this is the last sibling
void setParent(Menu &p);//Sets the Menu's Parent to p
void addSibling(Menu &s,Menu &p);//Adds a Sibling s with Parent p. If the Menu already has a sibling, ask that sibling to add it
public:
char *name;//Name of this Menu
//boolean (*canEnter)(Menu&);//Function to be called when this menu is 'used'
EnterFunc canEnter;
Menu(char *n);//Constructs the Menu with a name and a NULL use function (be careful calling it)
Menu(char *n, EnterFunc c );//Constructs the Menu with a specified use function
void addChild(Menu &c);//Adds the child c to the Menu. If the menu already has a child, ask the child to add it as a sibling
Menu * getChild(int which);//Returns a pointer to the which'th child of this Menu
Menu * getSibling(int howfar);//Returns a pointer to the sibling howfar siblings away from this Menu
Menu * getParent();//Returns this Menu's parent Menu. If no parent, returns itself
#endif //Menu_h
