Converting ps2 keyboard char to string
Hello
I am using ps2keyboard.h library.
Main problem is i cant export ps2 characters to one string.
This function will be responsible for reading keyboard text to call the function.
This function
Which function would that be ?
If writed characters(from keyboard) matches my string for example "/help"
Than program do other function
I need only to convert input characters from keyboard to string .
I cant use serial monitor(lcd 16x2 without serial connection)
To convert the single characters to a string add them to an array of chars as they arrive and when complete (how will you know this ?) put a zero in the next array position (or do it as you go along) and you have a C style string that you can compare with another string.
Are you talking about it?
StringToCharArray
Ohh... ok problem solved thanks
NorbertGrzegorczyk:
How did you solve it ?
Not by using StringToCharArray() I hope.
