Converting pulses into speed
Hi all, I have managed to get my Teensy Arduino to reliably count pulses using interrupts, and I'm now trying to turn that pulse rate into a speed but I'm struggling with the calculation.
The first problem I have is calculating toothDistance; it seems to equal zero, but I'm not sure why? What am I doing wrong with this calc?
Once I have this, my thought was to count the time taken between pulses and compare to the distance traveled, but I'm struggling to get it to work correctly - any help would be much appreciated... Here's what I have so far:
//Speed
volatile unsigned long VSS_count=0;
unsigned long VSS_prior_count=0;
int pin_VSS = 14;
void pulse() {
 VSS_count = VSS_count + 1;
int SPEED_MPH;
int SPEED_STEPS;
int SPEED_SEND;
int currentMillis;
int lastMillis;
unsigned long VSS_new_count;
int teeth = 17;
float diffRatio = 3.42;
int WheelCirc = 2126; //mm
float toothDistance; //= 36566.91;
float elapsedTime;
int speedRaw;
toothDistance = (1/teeth)/diffRatio*WheelCirc;
  //---Speed Input Count-----------------------------------
 pinMode(pin_VSS, INPUT_PULLUP);
 attachInterrupt(digitalPinToInterrupt(pin_VSS), pulse, RISING);
 NVIC_SET_PRIORITY(IRQ_PORTA, 0);
 currentMillis = millis();
 VSS_new_count = VSS_count;
 if (VSS_new_count != VSS_prior_count) {
  elapsedTime = (currentMillis - lastMillis)/1000;
  speedRaw = (toothDistance)/(elapsedTime);
  Serial.println(speedRaw);
 //VSS_prior_count = VSS_new_count;
All variables used with millis() should be unsigned long not int.
When does lastMillis ever get set to anything other than 0? What is count actually counting and why isn't the count part of the speed calculation?
Steve
assuming a pulse occurs for each tooth
60 * 1000 / (Npulse * dMsec)
where Npulse is the # of pulses per rotation (17) and dMsec is the average time between pulses.
while the interrupt can count pulse, it believe it should also measure the time between interrupts. dMsec = millis() - lastMsec
Ok so I have update the code to this, and now I get a string of zeros on the serial monitor with a speed populated every 50 or so lines. Also, what's the best way to work with the average pulse length, and elapsed time of maybe the last 10 pulses to try and get a stable reading..?
//Speed
int pin_VSS = 14;
void pulse() {
int SPEED_MPH;
int SPEED_STEPS;
int SPEED_SEND;
int currentMillis;
int lastMillis;
int teeth = 17;
unsigned long diffRatio = 3.42;
unsigned long toothDistance; //= 36566.91;
unsigned long elapsedTime;
unsigned long speedRaw;
//toothDistance = (1/teeth)/diffRatio*WheelCirc;
  elapsedTime = (millis() - lastMillis);
  speedRaw = 60 * 1000 / (teeth * elapsedTime);
  lastMillis = millis();
You access multibyte volatile data without making the access atomic, this only works most of the times.
It seems you should learn/refresh everything in Gammon Forum : Electronics : Microprocessors : Interrupts.
Whandall:
Thanks for the link, I will check it out. What do you mean by this though? You just completely blew my mind...
450nick:
Study the link, it´s very good and answers your question.
Ok, I now have a reliable speed figure now coming out.. But I have 2 problems:
The first is that I wanted to construct the length traveled per pulse of the tooth wheel using "(1/teeth)/(diffRatio*WheelCirc)" but the 1/teeth part seems to always return a zero. What's the best way of dealing with this calculation?
Furthermore, I'm currently only looking at each pulse on its own. Is there a neat way of averaging maybe the last 10 values on a rolling basis to give a smoother input?
Current code:
//Speed
int pin_VSS = 14;
void pulse() {
int SPEED_MPH;
int SPEED_STEPS;
int SPEED_SEND;
int currentMillis;
int lastMillis;
int teeth = 17;
float toothDistance=427701;   //(1/teeth)/(diffRatio*WheelCirc); //= 36566.91;
//toothDistance = (1/teeth)/(diffRatio*WheelCirc);
 if (VSS_count != VSS_prior_count) {
  VSS_prior_count = VSS_count;
  Serial.println(speedRaw/1000);
450nick:
Nope.
You still access multibyte volatile data from non ISR context without making the access atomic,
Would this then be adding:
noInterrupts ();
interrupts ();
That looks better but is incomplete, so who knows?
You should always post the complete code.
There are a lot of unnecessary (), why?
You are calling millis() twice, you are aware that both calls could return different values?
one way to avoid the "atomic" issue is to use bytes. are there likely to be >256 interrupts between when loop() runs? but i doubt this is the issue
the following will make the result smaller
is the integer math truncating any result to zero. making one of the constants a float by adding a decimal point will force the compiler to perform the computation using float. instead of printing RPM, check if elapsedTime make sense.
the equation is for a single increment of the count, the time between adjacent pulse.
(new - prior) * 60 * 1000.0 / (teeth * elapsedTime)
and do you really want a print every iteration of loop()? capturing the # of counts between prints will average
Thanks all for your help, I now have some code that works quite well, but the pointer on the output stepper motor is still a bit wavey... I've added the pulsegroup count so that it now averages over 10 reads. Perhaps I need to put a rolling average calculator on the SPEED_STEPS counter too?
#include <AccelStepper.h>
// Define some steppers and the pins the will use
AccelStepper stepper1(AccelStepper::DRIVER, 5, 6);
const int RESET = 18; // pin for RESET
int pin_VSS = 14;
void pulse() {
int SPEED_MPH;
int SPEED_STEPS;
int SPEED_SEND;
int currentMillis;
int lastMillis;
int teeth = 17;
float toothDistance=(1.0/(teeth));
float disttravelled = WheelCirc/diffRatio;
int pulsegroup = 0;
  pinMode(RESET, OUTPUT);
  digitalWrite(RESET, LOW);
  delay(1);  // keep reset low min 1ms
  digitalWrite(RESET, HIGH);
    stepper1.setMaxSpeed(10000.0);
    stepper1.setAcceleration(50000.0);
    stepper1.runToNewPosition(3780);
    stepper1.runToNewPosition(0);
toothDistance = toothDistance*disttravelled;
void loop(){
  noInterrupts ();
  interrupts ();
pulsegroup = VSS_new_count - VSS_prior_count;
 if (pulsegroup >9) {
  speedRaw = ((VSS_new_count - VSS_prior_count)*60*1000/(toothDistance*elapsedTime))/10;
SPEED_STEPS = map(speedRaw,10,200,0,3780);
    stepper1.moveTo(SPEED_STEPS);
    stepper1.run();
Here's a video of the stepper running: LINK
Also here's the code for the pulse generating arduino:
/* 2126mm per tyre revolution = 470 revs per km
diff ratio 3.42 so 1607 revs per km on gearbox = 1.6074 revs per m
So 10mph = 4.4704 m/s = *3.42 diff ratio = 7.19 revs/s = 122.23 pulses /s (17 teeth on gearbox wheel)  = interval time of 8.181ms = 8181
200mph = 89.408 m/s = 42.0545 revs/s *3.42 diff ratio = 143.826 GB revs/s = 2445.05 pulses /s = interval time of 0.4089ms = 409
int sensorPin = A0;              // select the input pin for the potentiometer
unsigned long potReading = 0;            // variable to store the value coming from the sensor
unsigned long val = 0;                    //value to be used with map
const int speedled =  13;      // the number of the LED pin //speed pulse
const int speedpin =  12;      // the number of the pulse pin //speed pulse
int ledState = LOW;            // ledState used to set the LED
int ledState2 = LOW;           // ledState used to set the LED
unsigned long previousMicros = 0;      // will store last time LED was updated
unsigned long interval = 500;          // interval at which to blink (milliseconds
unsigned long time = 0;
unsigned long previousTime = 0;      // will store last time Time was updated
float Hz = 0;
int i = 1;
  // Serial.println("Start...");
  // set the digital pin as output:
  pinMode(speedpin, OUTPUT);
  pinMode(speedled, OUTPUT);
  potReading = analogRead(sensorPin);
  //Serial.println(analogRead(sensorPin));
  potReading = potReading*potReading;
  potReading = potReading/100;
  interval = map(potReading, 10465, 100, 8181, 409);        // interval adjuster from .40ms to 8.18ms //8196   1169
  unsigned long currentMicros = micros();
  time = currentMicros - previousMicros;
  if (time > interval)                             // 17 cycles of HIGH to LOW on pin 14 speedpin (17 teeth on T56 speed sensor)
    previousMicros = currentMicros;
    i++;
    if (i == 2)
      time = currentMicros - previousTime;
      previousTime = currentMicros;
      Hz = 1000000.0 / time;
      Serial.println(Hz, 2);                     // 2 digits
      ledState = !ledState;                      //  1 -> 0 -> 1 -> 0 etc
      digitalWrite(speedpin, ledState);
      digitalWrite(speedled, ledState);
nick,
may i ask why you display the speed thru a stepper motor?
that is an analogue display; is that better than digital?
john.
HillmanImp:
nick,
john.
I'm building a restomod TVR Chimaera and have decided to build my own dash display to match the Sagaris instrument pod design, but with some of my own tweaks. I really like the analogue look much more than digital dash displays so I've kept my display to an absolute minimum with a tiny 128x32 OLED to display odometer and some engine data as required. Here's a link to my build diary which has some pictures of the dash design and overall ideas: BUILD DIARY
someone on another forum said the used stepper motor in analog dials for aviation cockpits. Bu they used encoder to verify the position of the motor.
you may want to consider leaky integration averaging
An = (sn - An-1) / Rate
You still introduce possible inconsistency by using two calls of millis, why?
gcjr:
How would one include that in one's Arduino project...?
Whandall:
  speedRaw = ((VSS_new_count - VSS_prior_count)601000/(toothDistance*elapsedTime))/10;
FIXED! Sorry... Any ideas on making the pointer more stable?
450nick:
Not in the code I can see.
Is it still unstable?
Are the speed values unstable?
First dividing (probably without rounding) and then multiplying via map forces the needle to be jumpy IMHO.
It's hard to estimate the integer math artefacts this expression could generate.
450nick:
A is the average and 's' is the current measurement. (you can initialize A to s at startup)
