converting serial.read to double
Hello,
I have written a program in Visual Basic that sends float (double) Numbers to the Arduino using the serial interface.
Is there a easy to do solution to convert the received data into double numbers, which I may save in global variables to do calculations with them later on?
The string which my visual basic application sends is formated that way:
d{0,0125}s{45,56987}r{1015,45}...
BR,
Andreas
Arduino doesn't have true double, double is an alias for float.
Store the data in an array of chars and use atof() to convert it to a float.
Just out of interest, does atof cope with commas as decimal points?
AWOL:
Nope. They'll have to send it using decimals instead, replace the commas with decimals as they come in, or edit the atof() source.
Hello,
if I use the following code to convert a string to double it works:
double test = 0;
test = atof("3,1456");
Serial.print(test * 2);
This is the function, which shall do the conversion:
// Seriellen Input in Double umwandeln
double MyConvertSerialInputIntoDouble(char tempEndCharacter) {
// Variable beinhaltet das über die serielle Schnittstelle empfangene Zeichen.
char tempReceivedCharacter = '#';
// Der String welcher die Empfangenen Zeichen beinhaltet.
String tempCharacterString = "";
// Die ermittelte Gleitkommazahl.
double tempDoubleNumber = 0;
// Die Schleife erst Verlassen, wenn das End-Zeichen empfangen wurde.
while(true) {
// Wenn ein neues Zeichen empfangen wurde.
if (Serial.available() > 0) {
// Zeichen auf der seriellen Schnitstelle empfangen.
tempReceivedCharacter = Serial.read();
// Schleife beenden, wenn das Zeichen zum Beenden empfangen wurde.
if (tempReceivedCharacter == tempEndCharacter) {
// Schleife beenden.
// Das Coma zu einem Punkt umwandeln.
if (tempReceivedCharacter == ',') {
// Umwandlung.
tempReceivedCharacter = '.';
// Den empfangenen String mit den schon bestehenden Zeichen verbinden.
tempCharacterString.concat(tempReceivedCharacter);
delay(1);
double test = 0;
test = atof(tempCharacterString);
Serial.print(test);
But I get this error message:
PLASMA_CUTTER_RECEIVING_DATA.ino: In function 'double MyConvertSerialInputIntoDouble(char)':
PLASMA_CUTTER_RECEIVING_DATA:90: error: cannot convert 'String' to 'const char*' for argument '1' to 'double atof(const char*)'
Andreas1984:
That seems pretty straight forward to me. atof() expects a const char* argument, and you're trying to send it a String object. Choose String objects or c-style strings, and stick with it. More information on the differences:
Finally I got it working:
here is the solution...
// Variable zur Umwandlung des Strings in char.
char tempCharArray[10] = "";
while(true) {
// Umwandlung.
// Verzögerung einbauen.
delay(1);
// Umwandlung des Strings in ein char Array.
tempCharacterString.toCharArray(tempCharArray, 10);
// Umwandlung des char Arrays in eine double Zahl.
tempDoubleNumber = atof(tempCharArray);
// Die Zahl double Zahl zurückgeben.
return tempDoubleNumber;
Why use a String and a string?
Just build a string, and forget you ever heard about the String class.
