Converting sinusoidal hall sensor input (varying frequency) to constant voltage
Hello, I'm still new to arduino and I'd like to ask for little help. Is it possible to make converter, which proportionally would change input from hall sensor (with varying frequency of sinusoidal input, depending on bicycle crankset rpm/cadence, powered by 5V) to stable voltage within range of, let say [1V...4V]? Cranks are going to have installed disc with magnets, given number of magnets would indicate 1 full turn of cranks. Hall sensor is going to be installed near bottom bracket. I'd like to have hall throttle signal emulated by above circuit. Throttle signal for my brushed motor controller must be within 1V to 4V. My dc motor max rpm at crankset is 82 rpm without load, 330rpm at motor shaft, I'd like motor to try to spin cranks by 1 rpm faster, than my cadence, so in reality I'd be helping motor to draw less current. Probably the best option would be to use potentiometer to adjust offset between pedalling rpm and motor rpm, as under load, motor rpm would drop, so this way I could adjust the level of power assist. In practice potentiometer would adjust output voltage offset to given cadence, eg lower or increase V out in very small increments (narrow range of voltage to be adjusted by full travel of pot knob). That's my concept, but unfortunately I'm not good at all in programming. I had this idea because I can't find brushed motor controller with power assist support, this in theory could help anyone to have power assist as an add on to any kind of electric bicycle.
I'd appreciate any help, thank you
This is only thing I found that could help me but I'm not sure is the code correct for what I'm trying to achieve.
/*  _   _   _   _   _   _   _   _   _   _   _   _   _   _   _   _   _   _   _   _
 * / \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \
 * \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/
 * Sets an E-Bike throttle proportinal to the Cadence of the rider
 * 	for more information visit
 * 		www.ideahex.com
 * Written by Damian Kleiss
 * \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \_/ \*/
// Definitions
#define CADENCE_PIN 2	// cadence sensor connected to pin 2 external interrupt 0
#define OVERIDE_PIN 4	// overide switch sensor connected to pin 4
#define THROTTLE_PIN 5	// throttle output connected to pin 5
// note "The PWM outputs generated on pins 5 and 6 will have higher-than-expected duty cycles"
#define CADENCE_MAGNETS 5
#define THROTTLE_MIN 80		// Min value required before power is applied to the motor
#define THROTTLE_MAX 240	// A larger throttle value will not result in more power
#define THROTTLE_OFF 0
#define CADENCE_MIN	15	// minimum cadence for motor to run
#define CADENCE_MAX	80	// cadence value that will result in full throttle
#define MAX_CADENCE_PERIOD 60000/(CADENCE_MIN*CADENCE_MAGNETS)	// Convert rpm to period
#define THROTTLE_STEP (THROTTLE_MAX-THROTTLE_MIN)/(CADENCE_MAX-CADENCE_MIN)	// Throttle ramp value
// Global Variables //
volatile int throttleValue = 0;
// Cadence Variables
volatile float currentCadence = 0;
volatile int cadenceState = 0;
volatile long cadencePositiveTimer = 0;
volatile long cadencePositivePeriod = 0;
volatile long cadenceNegativeTimer = 0;
volatile long cadenceNegativePeriod = 0;
volatile int cadenceInteruptFlag = 0;
unsigned long cadenceInterruptMillis = 0;
	Serial.println("ideaHex Throttle Test");
	Serial.println("Visit ideahex.com\r\n");
	pinMode(CADENCE_PIN, INPUT);
	pinMode(OVERIDE_PIN, INPUT_PULLUP);	// Use internal pullups
	pinMode(THROTTLE_PIN, OUTPUT);
	attachInterrupt(0, CadenceInterruptHandler, CHANGE);	// External interrupt for cadence sensor
	// Just set Throttle to Max if Over ride pressed
	while(digitalRead(OVERIDE_PIN)==LOW)	// Switch pulls to ground when pressed
		analogWrite(THROTTLE_PIN, THROTTLE_MAX);
	// As there won't be an interrupt if the pedals have stopped
	// check if a period longer than the minimum rpm has passed since
	// the last interrupt. If so set the throttle to minimum
	if(millis() - cadenceInterruptMillis > MAX_CADENCE_PERIOD)
		throttleValue = THROTTLE_OFF;
	// Check if an interrupt has occured
	if(cadenceInteruptFlag == HIGH)
		cadenceInterruptMillis = millis(); // reset time since last interrupt for min rpm
		ProcessCadence();	// Update cadence rpm value
		cadenceInteruptFlag = LOW; // reset flag
		Serial.print("cad = ");
		Serial.print(currentCadence,1);	// Show 1 decimal place
		if(currentCadence > CADENCE_MAX) throttleValue = THROTTLE_MAX;
		else if(currentCadence < CADENCE_MIN) throttleValue = THROTTLE_OFF;
		else throttleValue = ((currentCadence-CADENCE_MIN)*THROTTLE_STEP)+THROTTLE_MIN;
		Serial.print(", Throttle = ");
		Serial.println(throttleValue);
	analogWrite(THROTTLE_PIN, throttleValue); // Actualy output the throttle value
void CadenceInterruptHandler()
	if(digitalRead(CADENCE_PIN) == HIGH) // Positive period
		cadencePositiveTimer = millis();
		cadenceNegativePeriod = millis() - cadenceNegativeTimer;
	else if(digitalRead(CADENCE_PIN) == LOW) // Negative period
		cadencePositivePeriod = millis() - cadencePositiveTimer;
		cadenceNegativeTimer = millis();
		cadenceInteruptFlag = HIGH;	// set a flag so we know a pulse has occurred
void ProcessCadence()
	// Check if pedaling forward
	if (cadencePositivePeriod > cadenceNegativePeriod)
		float period = float(cadencePositivePeriod + cadenceNegativePeriod)/60000;
		currentCadence = (1/period)/CADENCE_MAGNETS;
	// If not pedalling forward set cadence to zero
	else currentCadence = 0;
The code you posted does an analogWrite() which is a pulse width modulated (PWM) signal. If you really need to convert that to a true analog voltage from 1-4 volts, you can add some external low pass filter on the pin.
https://arduino-info.wikispaces.com/Analog-Output
