Converting String to binary code
Hey there,
I would like to convert a String to a String of binary code at runtime.
Like:
String myText = "Hello World";
String binaryText = "0100100001100101011011000110110001101111001000000101011101101111011100100110110001100100";
Unfortunately I don't have a clue how to do it.
Can somebody help me?
Thank You!
a clue only:
byte *p = myText;
while (*p != 0)  { Serial.print(*p, BIN); p++; }
bitRead
You can do it like this. In my sketch the least significant bits of each character are printed first, so the output will look a little different than what you posted. Is that OK?
// Text to binary using serial monitor input
// Tom Fangrow, August 10, 2012
  Serial.begin(9600);         // open serial port at 9600 baud
  if(Serial.available()) {    // if anything on port
    byte c = Serial.read();   // read one character
    for(int i=0; i<8; i++) {
      Serial.print(c%2);      // print the least significant bit
      c /= 2;                 // move to next significant bit
Thank you all for the reply! :slight_smile:
This is my solution:
for(int i=0; i<myText.length(); i++){
   char myChar = myText.charAt(i);
    for(int i=7; i>=0; i--){
      byte bytes = bitRead(myChar,i);
      Serial.print(bytes, BIN);
    Serial.println("");
