Converting Strings to Longs
Ok, I admit it, this one has me beat. I've googled and spent more than a few hours trying out ideas and I'm stumped. I've built a parser for a serial stream that takes name/value pairs. I need to convert the 'value' to longs (timestamp). I need a function that is defined as folows:
long convertString (String str);
I can then call it to covert my values if they are of type long
I've tried the atoi() function and I must be missing something. Trid strtol() and couldn't make that work either.
If anyone can help it would be much appreciated.
Regards
Mudgee
For arduino-0019 and followers:
// Illustration of a function to convert a String
// to a long int using the C library function atol()
// (Arduino version 19 and successors)
// </begin Editorial>
// Why (oh why) didn't they just put something like the following
// in WString.h?
//      const char * c_str() const {return _buffer;}
// Then the main program could have done something like the following
//    long x = strtol(str.c_str(), NULL, 10);
// </end Editorial>
//  davekw7x
    String str("-12345678");
    Serial.print("The string   : ");
    Serial.println(str);
    long x = stringToLong(str);
    Serial.print("The long int : ");
    Serial.println(x);
// I would have preferred the argument to be (const String & s)
// but that would be inconsistent with the lame definition of
// toCharArray in WString.h
// It also would have required the prototype to be in a separate
// header, since the Arduino prototype collector doesn't
// work with arguments that are references.
// Oh, well...
//  davekw7x
long stringToLong(String s)
    char arr[12];
    s.toCharArray(arr, sizeof(arr));
    return atol(arr);
Output:
T
he string   : -12345678
The long int : -12345678
Note that a "better" function might have some kind of error checking, using that feature of strtol (or even using something other than strtol).
Anyhow, this might be a start.
Regards,
Dave
Thanks Dave - this works a treat. Very much appreciated. Now I can get on with the rest of the project.
Cheers :slight_smile:
