Converting The value receive from hex string to Decimal
Hello,
I am try to convert the HEX String to Decimal value ..
for an example ,
int Byte 1 : 7A
int Byte 2 :2A
String x= 7A2A
i need to convert this value to decimal value..thank you...
If you use a nul terminated character array instead of String with capital S, you can use strtol.
  char input[] = "7A2A";
  int x;
  char *endptr;
  x = strtol(input, &endptr, 16);
  Serial.begin(250000);
  Serial.println(x, HEX);
  Serial.println(x, DEC);
Output
7A2A
31274
You can use endptr to validate the input; the value that it points to should be NULL (the nul terminating character at the end of input) if the string is valid.
  char input[] = "7A2Z";
  int x;
  char *endptr;
  Serial.print("address of input = "); Serial.println((int)input);
  Serial.print("endptr points to "); Serial.println((int)endptr);
  Serial.print("value at endptr = "); Serial.println((char)*endptr, HEX);
  if (*endptr == NULL)
    Serial.println("input is valid");
    Serial.println("input is invalid");
The output
address of input = 2287
endptr points to 2290
value at endptr = 5A
input is invalid
