I've found this piece of code on-line that generates a timer interrupt and it works pretty well.
Link here http://www.hobbytronics.co.uk/arduino-timer-interrupts
#define ledPin 13
int timer1_counter;
pinMode(ledPin, OUTPUT);
// initialize timer1
noInterrupts(); // disable all interrupts
TCCR1A = 0;
TCCR1B = 0;
// Set timer1_counter to the correct value for our interrupt interval
//timer1_counter = 64886; // preload timer 65536-16MHz/256/100Hz
//timer1_counter = 64286; // preload timer 65536-16MHz/256/50Hz
timer1_counter = 34286; // preload timer 65536-16MHz/256/2Hz
TCNT1 = timer1_counter; // preload timer
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << TOIE1); // enable timer overflow interrupt
interrupts(); // enable all interrupts
ISR(TIMER1_OVF_vect) // interrupt service routine
digitalWrite(ledPin, digitalRead(ledPin) ^ 1);
// your program here...
The issue I have is that what I want to use it for involves using servos which use the same timer as this code (timer 1).
So I want to make this code work off of timer 2 instead, however I'm not sure what I have to change to do that; I've tried changing all the 1's in the AVR declarations into 2's in various ways but haven't had any luck.
Can anyone tell me what I'm doing wrong or suggest the right datasheet to help fix this?
