I have some output to the LCD like this:
lcdSerial << "AZ ";
lcdSerial << _FLOAT(azFloat, 1) << azRotorMovement ; // Then print the line including the wish rotor angle
How can i convert this to a single string so i can add som speces to fit on the LCD saving two commands to clear that line first.
system
April 10, 2013, 10:28am
2
sprintf() comes to mind, except for the float. For that, you need dtostrf() first.
Solved the problem like this:
void displayAz(long az) {
double azFloat = az / 100.0; //adjust value for display
String _azString = "AZ ";
static char _azBuffer[7];
if (azFloat < 10.0) { // pad with spaces if needed
_azString += " ";
if (azFloat < 100.0){
_azString += " ";
#ifdef LCD_I2C
dtostrf(azFloat,4, 2, _azBuffer);
_azString = " " + _azString + _azBuffer;
_azString += azRotorMovement;
lcdSerial.setCursor(0,1);
lcdSerial << _azString;
// Serial << _azString << endl;
#else
lcdSerial << _BYTE(_line1) << _azString;
#endif
Now i only need to figure out how to mak each string 20 characters long
please note that String can cause trouble in pre 1.04 versions as the underlying free() was buggy.
_azString += " ";
_azString += " ";
Did you really go to all this bother to save 2 commands to clear the LCD line ?
Yes, any idea how to this different? Remember i am not a C++ programmer.
It was you that said that you wanted to save the 2 lines required to clear the line on the LCD so I presume that you know what they are.
You where quoting some code, so i am asuming that it was about those lines.
In my code i used this to clear a line of text later on:
#ifdef LCD_SER_4X20
#ifndef LCD_I2C
const byte _line2 = 0xA8; // lcd line 2 - 3th line
const byte _line3 = 0xBC; // lcd line 3 - bottom line
#endif
String _clearString = " ";
#else
#endif
And it either took 17 or 21 bytes in program memory.
Adding spaces to the actual line took less.
