Converting to integer
I'm reading characters in from a web site, putting them in a an array of chars, then converting it into an integer (it's always an integer).
Whatever the actual number the result comes back as 2289.
This is the relevant code snippet:
char bar[5] = "";
byte foo=0;
  char tmp = client.read();
  while (tmp != '\n') {  //line break signifies end of number
    bar[foo] = tmp;
    foo++;
  curUzr = int(bar);
That's probably the correct value for the address of your buffer
Have you tried 'atoi'?
How do I get the integer value of the string?
you haven't got a string until you terminate it.
Oh. I've added , but it still doesn't work (value has changed though, it's nw 2287). What have I missed?
char bar[5] = "";
byte foo=0;
    bar[foo] = tmp;
    foo++;
  char[foo]='\0';
  curUzr = int(bar);
I've just spotted your mention of atoi. What's that?
YES! That's done it. Thank you AWOL :smiley:
