I’m using an ESP8266 with the ArduinoJSON and PubSubClient libraries. Basically, I’m trying to read a JSON file and use its values to connect to an MQTT server. However, there are some typing issues that I can’t figure out. In the two lines I’ve marked below (66 and 145), the char arrays aren’t working as parameters for the functions to the MQTT library. There is no error, but the library doesn’t connect to the server. Placing actual values in those places (not variables) causes it to work perfectly. The variables from ArduinoJSON work fine for connecting to the WiFi, but not MQTT.
garage.ino:
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include "FS.h"
#include <ArduinoJson.h>
#include <PubSubClient.h>
#define CONFIG_FILEPATH "/config.json"
* DON'T TOUCH ANYTHING PAST THIS LINE!
const char* wifi_ssid;
const char* wifi_password;
const char* mqtt_host;
const char* mqtt_port;
const char* mqtt_clientname;
const char* mqtt_username;
const char* mqtt_password;
const char* mqtt_topic;
const char* mqtt_route_door1;
const char* mqtt_route_door2;
const char* mqtt_route_car1;
const char* mqtt_route_car2;
const char* mqtt_route_calibrate;
WiFiClient espClient;
PubSubClient client(espClient);
pinMode(LED_BUILTIN, OUTPUT);
Serial.begin (115200);
Serial.println("[Sys] Booting...");
if (!SPIFFS.begin()) {
Serial.println("[Sys] Failed to mount file system");
return;
if (!loadConfig()) {
Serial.println("[Sys] Failed to load config");
Serial.println("[Sys] Config loaded");
// if (!saveConfig()) {
// Serial.println("[Sys] Failed to save config");
// } else {
// Serial.println("[Sys] Config saved");
SPIFFS.end();
WiFi.begin(wifi_ssid, wifi_password);
Serial.print("[WiFi] Connecting");
Serial.print(".");
Serial.println("connected");
Serial.print("[WiFi] IP address: ");
Serial.print("[MQTT] Setting up: ");
Serial.println((String) mqtt_host);
// *********************************************************************** ISSUE HERE
client.setServer((uint8_t*) mqtt_host, (int) mqtt_port); // CAN'T GET THESE VARIABLES TO WORK
client.setCallback(mqttCallback);
mqttConnect();
if (!client.connected()) {
Serial.println("[MQTT] Not connected!");
mqttConnect();
client.loop();
/* functions for loading/saving config
* https://github.com/esp8266/Arduino/blob/master/libraries/esp8266/examples/ConfigFile/ConfigFile.ino
bool loadConfig() {
File configFile = SPIFFS.open(CONFIG_FILEPATH, "r");
if (!configFile) {
Serial.println("[Sys] Failed to open config file");
return false;
size_t size = configFile.size();
if (size > 1024) {
Serial.println("[Sys] Config file size is too large");
return false;
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
StaticJsonBuffer<200> jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
if (!json.success()) {
Serial.println("[Sys] Failed to parse config file");
return false;
wifi_ssid = json["wifi_ssid"];
wifi_password = json["wifi_password"];
mqtt_host = json["mqtt_host"];
mqtt_port = json["mqtt_port"];
mqtt_clientname = json["mqtt_clientname"];
mqtt_username = json["mqtt_username"];
mqtt_password = json["mqtt_password"];
mqtt_route_door1 = json["mqtt_route_door1"];
mqtt_route_door2 = json["mqtt_route_door2"];
mqtt_route_car1 = json["mqtt_route_car1"];
mqtt_route_car2 = json["mqtt_route_car2"];
mqtt_route_calibrate = json["mqtt_route_calibrate"];
return true;
bool saveConfig() {
JsonObject& json = jsonBuffer.createObject();
json["wifi_ssid"] = wifi_ssid;
json["wifi_password"] = wifi_password;
json["mqtt_host"] = mqtt_host;
json["mqtt_port"] = mqtt_port;
json["mqtt_clientname"] = mqtt_clientname;
json["mqtt_username"] = mqtt_username;
json["mqtt_password"] = mqtt_password;
json["mqtt_topic"] = mqtt_topic;
json["mqtt_route_door1"] = mqtt_route_door1;
json["mqtt_route_door2"] = mqtt_route_door2;
json["mqtt_route_car1"] = mqtt_route_car1;
json["mqtt_route_car2"] = mqtt_route_car2;
json["mqtt_route_calibrate"] = mqtt_route_calibrate;
File configFile = SPIFFS.open(CONFIG_FILEPATH, "w");
if (!configFile) {
Serial.println("[Sys] Failed to open config file for writing");
return false;
json.printTo(configFile);
return true;
/* MQTT functions */
void mqttConnect() {
while (!client.connected()) {
Serial.print("[MQTT] Connecting...");
if (client.connect(mqtt_clientname, mqtt_username, mqtt_password)) { // CAN'T GET THESE VARIABLES TO WORK
//client.publish("outTopic", "hello world");
// ... and resubscribe
client.subscribe(mqtt_route_door1);
client.subscribe(mqtt_route_door2);
client.subscribe(mqtt_route_calibrate);
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000);
void mqttCallback(char* topic, byte* payload, unsigned int length) {
Serial.print("[MQTT] Message arrived [");
Serial.print(topic);
Serial.print("] ");
String message = "";
for (int i = 0; i < length; i++) {
message += (char)payload[i];
Serial.print((char)payload[i]);
Serial.println(message);
config.json:
"wifi_ssid": "ssid",
"wifi_password": "pass",
"mqtt_host": "192.168.0.100",
"mqtt_port": 1883,
"mqtt_clientname": "myclient",
"mqtt_username": "user",
"mqtt_password": "pass",
"mqtt_route_door1": "garage/door1",
"mqtt_route_door2": "garage/door2",
"mqtt_route_car1": "garage/car1",
"mqtt_route_car2": "garage/car2",
"mqtt_route_calibrate": "garage/calibrate"
I know there’s an ESP8266 forum, but I’ve been given fantastic advice here, this is more of a C question, and all of these libraries work on standard Arduinos.
Thanks!
