Converting voltage to dB SPL
Hello all,
I currently have a microphone the is outputting voltage values to the Arduino serial monitor.
What calculations would i have to perform on this voltage to convert it to dB SPL?
A calibration curve.
To expand:
Youll need to either find the output voltage vs decibel graph provided by the microphones spec sheet.
OR
Make your own graph using known sound levels and plotting a function/ Look up table.
Have you tried a Google search?
Have a read of this page:- How to convert Volts in dB SPL
In particular:-
(If) Your microphone has a sensitivity of -46dBV/Pa , this gives 0.005012 V RMS/ Pa 1 Pa (pascal) equals 94 dB sound pressure (SPL)
The dB equation for voltage is 20×logV1Vo
where V1 is the voltage being measured, and Vo the reference level
If we do an example calculation for the measurement of 2.5v (assuming a unity gain for the amplifier) we get
20×log2.50.005012=53.96dB
so the SPL will be (-46) + 53.96 = 7.95 + 94 = 101.95 Db SPL
We assumed a unity gain for the preamplifier, if the actual gain was 20dB then the SPL becomes 101.95 - 20 = 81.95 Db SPL
if the actual gain was 10dB then the SPL becomes 101.95 - 10 = 91.95 Db SPL ...
OldSteve: Have you tried a Google search?
In particular:-
Oooops. Here is me assuming they may be non-linear.
In the real world SPL meters are calibrated against a known good SPL meter. So you generally need an SPL meter in order to build one, and if you have a reference SPL meter, you don't need to know the sensitivity of the microphone.
But, "real" SPL measurements are [u]weighted[/u] and averaged, so although you can make an SPL meter that "works", it's not easy to make a proper SPL meter for "serious" measurements.
And I think I remember that they have different weighted curves as well.
