why my code doesn't running correctly. first, the code for water flow sensor not working/doesn't running when ir sensor 1 detecting object. second, when i push S button in keypad to save the data, the LCD show saving views, but not come back to main views (lcd show blank). the code is below. plis help me to done my project. sorry for my english :). note : Let's just say that the circuit schematic is correct.
/*--------------------------- Inisialisasi Keypad 4x4 ---------------------------*/
#include <Keypad.h>
const byte ROWS = 4; //4 baris
const byte COLS = 4; //4 kolom
char keys[ROWS][COLS] = {
{ '1', '2', '3', 'A' },
{ '4', '5', '6', 'B' },
{ '7', '8', '9', 'C' },
{ '*', '0', 'S', 'D' } //S = Simpan
byte colPins[COLS] = { 6, 5, 4, 3 }; // pin 2,3,4,5 untuk pin kolom keypad (lihat gambar)
byte rowPins[ROWS] = { 10, 9, 8, 7 }; // pin 6,7,8,9 untuk pin baris keypad (lihat gambar)
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
char key;
#define maksBit 4
char userInput[maksBit];
byte hitungData = 0;
int userInputInt = 0;
/*--------------------------- Akhir Keypad 4x4 ---------------------------*/
/*--------------------------- Inisialisasi LCD I2C ---------------------------*/
LiquidCrystal_I2C lcd(0x26, 16, 2); // SDA: A4, SCL:A5.
/*--------------------------- Akhir LCD I2C ---------------------------*/
/*--------------------------- Inisialisasi Sensor Water Flow ---------------------------*/
volatile int flow_frequency;
float l_minute;
float totalIsi = 0.0;
unsigned char flowsensor = 2; // Sensor Input
unsigned long currentTime;
unsigned long cloopTime;
/*--------------------------- Akhir Sensor Water Flow ---------------------------*/
/*---------------------- Inisialisasi Relay Pompa Air ------------------------*/
byte relayPompa = A0; //pin POMPA
#define pompaAktif LOW
/*---------------------- Akhir Relay Pompa Air ------------------------*/
/*-------------------- Inisialisasi Relay Motor Konveyor ---------------------*/
byte relayKonveyor = A1; //pin Relay Konveyor
#define konvAktif LOW
/*-------------------- Akhir Relay Motor Konveyor ---------------------*/
/*--------------------------- Inisialisasi Sensor Infrared 1 ---------------------------*/
int SensorIR1 = 11;
#define adaBarang LOW
/*--------------------------- Inisialisasi Sensor Infrared 2 ---------------------------*/
int SensorIR2 = 12;
// #define adaBarang HIGH
/*--------------------------- Inisialisasi EEPROM ---------------------------*/
#include <EEPROM.h>
#define address 10
/*--------------------------- Akhir EEPROM ---------------------------*/
void flow() // Interrupt function
flow_frequency++;
pinMode(relayKonveyor, OUTPUT); //Konveyor Pin
pinMode(relayPompa, OUTPUT); //Motor Pin
pinMode(SensorIR1, INPUT); //Sensor IR 1
pinMode(SensorIR2, INPUT); //Sensor IR 2
/*--------------------------- Setup LCD I2C ---------------------------*/
lcd.init();
lcd.backlight();
/*--------------------------- Setup Sensor Water Flow ---------------------------*/
pinMode(flowsensor, INPUT);
digitalWrite(flowsensor, HIGH); // Optional Internal Pull-Up
attachInterrupt(digitalPinToInterrupt(flowsensor), flow, RISING); // Setup Interrupt
currentTime = millis();
cloopTime = currentTime;
/*--------------------------- Utama ---------------------------*/
lcd.setCursor(0, 0);
lcd.print("AUTOMATIC BOTTLE");
lcd.setCursor(0, 1);
lcd.print("FILLER MACHINE");
delay(2000);
lcd.clear(); // Menghapus seluruh Output pada LCD
viewLCD();
stopIsi();
startKonv();
Baca();
key = keypad.getKey();
if (key) {
pencetan(key);
if (digitalRead(SensorIR1) == adaBarang) {
stopKonv();
while (totalIsi <= userInputInt && digitalRead(SensorIR1) == adaBarang) {
stopKonv();
startIsi();
stopIsi();
startKonv();
} else if (digitalRead(SensorIR2) == adaBarang) {
stopKonv();
} else if (digitalRead(SensorIR2) == adaBarang && digitalRead(SensorIR2) == adaBarang) {
stopKonv();
startKonv();
totalIsi = 0;
/*--------------------------- Awal Fungsi LCD I2C ---------------------------*/
void viewLCD() {
//ATAS
lcd.print("MAX ISI:");
lcd.setCursor(14, 0);
lcd.print("mL");
//BAWAH
lcd.print("ISI:");
lcd.setCursor(14, 1);
lcd.print("mL");
void viewSimpan() {
lcd.clear();
lcd.setCursor(4, 0);
lcd.print("TERSIMPAN!");
lcd.setCursor(7, 1);
Baca();
delay(50);
lcd.print(userInputInt);
lcd.clear();
delay(10);
/*--------------------------- Akhir Fungsi LCD I2C ---------------------------*/
/*--------------------------- Awal Fungsi Keypad 4x4 ---------------------------*/
void pencetan(char Key) {
Serial.println(Key);
String s;
if (Key == 'A') {
s = "100";
s.toCharArray(userInput, maksBit);
lcd.setCursor(9, 0);
lcd.print("100");
hitungData = +3;
} else if (Key == 'B') {
s = "250";
lcd.print("250");
hitungData = +3;
} else if (Key == 'C') {
s = "500";
lcd.print("500");
hitungData = +3;
} else if (Key == 'D') {
hitungData--;
userInput[hitungData] = NULL;
lcd.setCursor(hitungData + 9, 0);
lcd.print(userInput[hitungData]);
else if (Key == 'S') {
Simpan();
clearData();
} else if (Key == '*') {
lcd.clear();
Baca();
lcd.print("Nilai Sekarang:");
lcd.clear();
userInput[hitungData] = Key;
hitungData++;
if (hitungData == maksBit + 1) {
lcd.clear();
lcd.print("maks. bit = 4");
delay(1500);
clearData();
lcd.clear();
Serial.println(userInput);
void clearData() {
while (hitungData >= 0) {
userInput[hitungData--] = 0;
/*--------------------------- Akhir Fungsi Keypad 4x4 ---------------------------*/
/*--------------------------- Awal Fungsi EEPROM ---------------------------*/
void Simpan() {
String b;
b = String(userInput[0]) + String(userInput[1]) + String(userInput[2]) + String(userInput[3]);
int number = b.toInt();
EEPROM.update(address, number >> 8);
EEPROM.update(address + 1, number & 0xFF);
delay(5);
viewSimpan();
b = "";
number = NULL;
int ambilData() {
return (EEPROM.read(address) << 8) + EEPROM.read(address + 1);
void Baca() {
userInputInt = ambilData();
Serial.println(userInputInt);
/*--------------------------- Akhir Fungsi EEPROM ---------------------------*/
/*--------------------------- Awal Fungsi Sensor Water Flow ---------------------------*/
void totalAir() {
// Every second, calculate and print litres/hour
if (currentTime >= (cloopTime)) {
cloopTime = currentTime; // Updates cloopTime
if (flow_frequency != 0) {
l_minute = ((flow_frequency * 16.67) / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour. 16.67 is value from converting L/hour to mL/second
l_minute = l_minute / 60;
totalIsi += l_minute;
flow_frequency = 0; // Reset Counter
Serial.println(totalIsi, 2);
//interrupt function added above void setup
/*--------------------------- Akhir Fungsi Sensor Water Flow ---------------------------*/
/*--------------------------- Awal Fungsi Pompa Air & Solenoid Valve ---------------------------*/
void startIsi() {
digitalWrite(relayPompa, pompaAktif);
totalAir();
lcd.clear();
lcd.setCursor(9, 1);
lcd.print(totalIsi);
void stopIsi() {
digitalWrite(relayPompa, !pompaAktif);
totalIsi = 0; //reset pembacaan isi botol
/*--------------------------- Akhir Fungsi Pompa Air & Solenoid Valve ---------------------------*/
/*--------------------------- Awal Fungsi Konveyor ---------------------------*/
void startKonv() {
digitalWrite(relayKonveyor, konvAktif);
void stopKonv() {
digitalWrite(relayKonveyor, !konvAktif);
/*--------------------------- Akhir Fungsi Konveyor ---------------------------*/
