Does any one have code for Conway's Game of Life that will restart itself when it either dies out, gets stuck on a still image, or gets stuck in a repeating pattern? I have tried for awhile but can't seem to make it work right and would like some help.
This is the original code I had and I know works, but only runs "one game." It is from http://www.instructables.com/id/810-LED-Matrix-with-4017/
// 10*8 LED matrix with 4017 IC
// Made by Vadim S.
//On 25.06.2009
#define XSIZE 10
#define YSIZE 8
int DataPin = 9;
int LatchPin = 11;
int ClockPin = 10;
int clock = 13;
int Reset = 12;
int a;
byte world[10][8][2];
long density = 50; // The density of the population on the the screen
byte bank[] = {
B00000001,B00000010,B00000100,B00001000,B00010000,B00100000,B01000000,B10000000}; // a pool of bytes
// set up
byte leds_1[10] = {
B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000};
byte leds_2[10] = {
void setup(){
pinMode(DataPin,OUTPUT);
pinMode(ClockPin,OUTPUT);
pinMode(LatchPin,OUTPUT);
//simple stuff here
pinMode(clock,OUTPUT);
pinMode(Reset,OUTPUT);
//reseting the 4017 IC, you have to do this
digitalWrite(Reset,HIGH);
delayMicroseconds(5);
digitalWrite(Reset,LOW);
randomSeed(analogRead(5));// a random seed for the random start pattern
// random papulation of the screen
for (int i = 0; i < 10; i++) {
for (int j = 0; j < 8; j++) {
if (random(100) < density) {
world[i][j][0] = 1;
leds_1[i]+=bank[j];
leds_2[i] = leds_1[i];
else {
world[i][j][0] = 0;
world[i][j][1] = 0;
void loop(){
display_pattern_1(50);
// Birth and death cycle
for (int x = 0; x < 10; x++) {
for (int y = 0; y < 8; y++) {
// Default is for cell to stay the same
world[x][y][1] = world[x][y][0];
int count = neighbours(x, y);
if (count == 3 && world[x][y][0] == 0) {
// A new cell is born
world[x][y][1] = 1;
leds_2[x] += bank[y];
if ((count < 2 || count > 3) && world[x][y][0] == 1) {
// Cell dies
world[x][y][1] = 0;
leds_2[x] -= bank[y];
// Copy next generation into place
world[x][y][0] = world[x][y][1];
leds_1[x] = leds_2[x];
// This function is for the 4 laws in conway's game of life
int neighbours(int x, int y) {
return world[(x + 1) % XSIZE][y][0] +
world[x][(y + 1) % YSIZE][0] +
world[(x + XSIZE - 1) % XSIZE][y][0] +
world[x][(y + YSIZE - 1) % YSIZE][0] +
world[(x + 1) % XSIZE][(y + 1) % YSIZE][0] +
world[(x + XSIZE - 1) % XSIZE][(y + 1) % YSIZE][0] +
world[(x + XSIZE - 1) % XSIZE][(y + YSIZE - 1) % YSIZE][0] +
world[(x + 1) % XSIZE][(y + YSIZE - 1) % YSIZE][0];
void display_pattern_1(int loops){
for(int t=0;t<loops;t++){
for(a=0;a<10;a++){
digitalWrite(LatchPin, 0);
shiftOut(DataPin, ClockPin,MSBFIRST,leds_1[a]);
digitalWrite(LatchPin, 1);
delayMicroseconds(800);
shiftOut(DataPin, ClockPin,MSBFIRST,0);
digitalWrite(clock,HIGH);
digitalWrite(clock,LOW);
Also I would like to make another LED matrix with a max7219 IC. Is there a port of "Game of Life" for use with this IC? Preferably one that also has an auto restart when it dies out.
