Made a Lill block (4650 Bytes) of code to control all the movments of my 4 servos
Heres a very short vid of them panning 180, Yes very boring...
This Second video is what I have made with 4 Servos and a Block of code, Made a lill Arm Worked alight
#include <Servo.h>//Servo Header
Servo Servo1,Servo2,Servo3,Servo4;//Declare Servos
Servo servo[]={Servo1,Servo1,Servo2,Servo3,Servo4};//Toss Into Array
int Pin[]={12,11,10,9};//Toss pins used into array
int CurrentPos[5];//Var for Current Postion
class ServoC{//Servo Class, Move, Update, Enable
public:
void Move(int,int,int,int,int,int,int,int,char,char,char,char,int);
int Update(int);
void Enable();
int ServoC::Update(int ServoNum){//Gets servo Pos
return(servo[ServoNum].read());
void ServoC::Enable(){//Enable Servos
for(int i=0;i<4;i++){
servo[i+1].attach(Pin[i]);
void ServoC::Move(int ServoNumber1,int ServoNumber2,int ServoNumber3,int ServoNumber4,int Servo1Deg,int Servo2Deg,int Servo3Deg,int Servo4Deg, char MoveType1, char MoveType2, char MoveType3, char MoveType4, int Spe){
int Max=0;//Max Value for the For loop
int Fmax[]={Servo1Deg,Servo2Deg,Servo3Deg,Servo4Deg};//Array for servo Degres
if(Fmax[i]>Max){//Finds largest number in the array
Max=Fmax[i];//Saves it
if(ServoNumber1!=0)CurrentPos[ServoNumber1]=Update(ServoNumber1);//If servo Number != 0 Update
if(ServoNumber2!=0)CurrentPos[ServoNumber2]=Update(ServoNumber2);//If servo Number != 0 Update
if(ServoNumber3!=0)CurrentPos[ServoNumber3]=Update(ServoNumber3);//If servo Number != 0 Update
if(ServoNumber4!=0)CurrentPos[ServoNumber4]=Update(ServoNumber4);//If servo Number != 0 Update
// Movement types
// + <- Adds Value to current posstion
// - <- Subtracts Value to current posstion
// = <- Makes servo go to Value
for(int i=0;i<Max;i++){//For loop for movment
if((ServoNumber1!=0)&&(MoveType1=='+')&&(i<Servo1Deg)){
servo[ServoNumber1].write(CurrentPos[ServoNumber1]+i);
if((ServoNumber2!=0)&&(MoveType2=='+')&&(i<Servo2Deg)){
servo[ServoNumber2].write(CurrentPos[ServoNumber2]+i);
if((ServoNumber3!=0)&&(MoveType3=='+')&&(i<Servo3Deg)){
servo[ServoNumber3].write(CurrentPos[ServoNumber3]+i);
if((ServoNumber4!=0)&&(MoveType4=='+')&&(i<Servo4Deg)){
servo[ServoNumber4].write(CurrentPos[ServoNumber4]+i);
if((ServoNumber1!=0)&&(MoveType1=='-')&&(Servo1Deg>i)){
servo[ServoNumber1].write(CurrentPos[ServoNumber1]-i);
if((ServoNumber2!=0)&&(MoveType2=='-')&&(Servo2Deg>i)){
servo[ServoNumber2].write(CurrentPos[ServoNumber2]-i);
if((ServoNumber3!=0)&&(MoveType3=='-')&&(Servo3Deg>i)){
servo[ServoNumber3].write(CurrentPos[ServoNumber3]-i);
if((ServoNumber4!=0)&&(MoveType4=='-')&&(Servo4Deg>i)){
servo[ServoNumber4].write(CurrentPos[ServoNumber4]-i);
delay(Spe);
if((ServoNumber1!=0)&&(MoveType1=='='))servo[ServoNumber1].write(Servo1Deg);
if((ServoNumber2!=0)&&(MoveType2=='='))servo[ServoNumber2].write(Servo2Deg);
if((ServoNumber3!=0)&&(MoveType3=='='))servo[ServoNumber3].write(Servo3Deg);
if((ServoNumber4!=0)&&(MoveType4=='='))servo[ServoNumber4].write(Servo4Deg);
delay(Spe);
void setup(){
ServoC S;
S.Enable(0);
Servo1.write(180);
Servo2.write(10);
Servo3.write(80);
Servo4.write(0);
ServoC S;
int time=1000;
S.Move(
1//Servo 1
,2//Servo 2
,3//Servo 3
,4//Servo 4
,180//Servo 1 Angle will be 180
,10//Servo 2 Angle will be 10
,80//Servo 1 Angle will be 18
,0//Servo 1 Angle will be 0
,'='//Servo 1 Angle will goto Angle
,'='//Servo 2 Angle will goto Angle
,'='//Servo 3 Angle will goto Angle
,'='//Servo 4 Angle will goto Angle
,10//Speed of servo per degree tick, +/- 50 degrees would take 500ms, Largest number is used for ammount of ticks
S.Move(0,0,3,4,180,10,80,50,'=','=','=','+',10);
S.Move(0,2,3,4,180,28,33,40,'=','+','+','-',10);
S.Move(0,2,3,4,180,5,25,18,'-','+','+','+',10);
S.Move(0,2,3,4,180,1,1,35,'-','-','-','+',10);
S.Move(0,2,3,4,180,20,20,10,'-','+','-','+',10);
S.Move(0,2,3,4,180,40,20,30,'-','+','+','-',10);
S.Move(1,2,3,4,45,53,68,18,'-','-','-','-',20);
S.Move(1,2,3,4,45,53,69,18,'-','-','-','-',20);
S.Move(1,2,3,4,45,24,34,11,'-','+','+','+',20);
S.Move(1,2,3,4,45,53,68,21,'-','-','-','-',20);
S.Move(0,2,3,4,45,90,180,40,'-','=','=','+',5);
Edit:
Added Coments
Added newer Code
Added 2nd Video
