Coordinating 6 LEDS with variables
Hi, I just got my Arduino and I started a basic laser tag gun to help me learn, now at the moment I haven’t yet implemented IR because that seems a bit above my skill level. However what I have been doing is making the basics of the gun. It can fire 6 shots before pausing to “reload” and then it continues, however my problem is, I’m trying to make LEDs display how many shots it holds however I’m getting multiple errors. I’ve attached the file and help would be much appreciated.
laserBASEv2.ino (1.86 KB)
I liked the part
if(bullets--0) bullets--bullets-1
dave-in-nj: I liked the part
sorry, I'm really new and don't understand
read about if() and syntax.
you start with an if() statement and the delay for 5 seconds. then change the value of bullets to
bullets=bullets-1
the sintax is
if(this == 0) { // the { goes after the end of the line.
you have it before the line
if(this==0);
Is this what you want?
const int LED = 13;
const int BUT = 7;
const int BULL = 2;
const int B2 = 3;
const int B3 = 4;
const int B4 = 5;
const int B5 = 6;
const int B6 = 9;
int bullets = 6;
int val = 0;       //set pins and variables
  pinMode(LED, OUTPUT);
  pinMode(BUT, INPUT);   //set pinmodes
  pinMode(BULL, OUTPUT);
  pinMode(B2, OUTPUT);
  pinMode(B3, OUTPUT);
  pinMode(B4, OUTPUT);
  pinMode(B5, OUTPUT);
  pinMode(B6, OUTPUT);
  val = digitalRead(BUT);
  if (val == HIGH)
    if(bullets == 0)
      delay(5000);
      digitalWrite(LED, HIGH);
      delay(250);
      digitalWrite(LED, LOW);
      bullets = bullets - 1;
    if(bullets == 6)
      digitalWrite(BULL, HIGH);
      digitalWrite(B2, HIGH);
      digitalWrite(B3, HIGH);
      digitalWrite(B4, HIGH);
      digitalWrite(B5, HIGH);
      digitalWrite(B6, HIGH);
        if(bullets == 5)
        digitalWrite(BULL, LOW);
          if(bullets == 4)
          digitalWrite(B2, LOW);
            if(bullets == 3)
            digitalWrite(B3, LOW);
              if(bullets == 2)
              digitalWrite(B4, LOW);
                if(bullets == 1)
                digitalWrite(B5, LOW);
                  if(bullets == 0)
                  digitalWrite(B6, LOW);
BillHo: Is this what you want?
const int LED = 13;
const int BUT = 7;
const int BULL = 2;
const int B2 = 3;
const int B3 = 4;
const int B4 = 5;
const int B5 = 6;
const int B6 = 9;
int bullets = 6;
{   pinMode(LED, OUTPUT);   pinMode(BUT, INPUT);  //set pinmodes   pinMode(BULL, OUTPUT);   pinMode(B2, OUTPUT);   pinMode(B3, OUTPUT);   pinMode(B4, OUTPUT);   pinMode(B5, OUTPUT);   pinMode(B6, OUTPUT); }
void loop() {    val = digitalRead(BUT);   if (val == HIGH)   {     if(bullets == 0)     {       delay(5000);     }     else     {       digitalWrite(LED, HIGH);       delay(250);       digitalWrite(LED, LOW);       bullets = bullets - 1;       delay(1000);     }     if(bullets == 6)     {       digitalWrite(BULL, HIGH);       digitalWrite(B2, HIGH);       digitalWrite(B3, HIGH);       digitalWrite(B4, HIGH);       digitalWrite(B5, HIGH);       digitalWrite(B6, HIGH);     }     else
        if(bullets == 5)       {
        digitalWrite(BULL, LOW);         digitalWrite(B2, HIGH);         digitalWrite(B3, HIGH);         digitalWrite(B4, HIGH);         digitalWrite(B5, HIGH);         digitalWrite(B6, HIGH);       }       else
          if(bullets == 4)         {
          digitalWrite(BULL, LOW);           digitalWrite(B2, LOW);           digitalWrite(B3, HIGH);           digitalWrite(B4, HIGH);           digitalWrite(B5, HIGH);           digitalWrite(B6, HIGH);         }         else
            if(bullets == 3)           {
            digitalWrite(BULL, LOW);             digitalWrite(B2, LOW);             digitalWrite(B3, LOW);             digitalWrite(B4, HIGH);             digitalWrite(B5, HIGH);             digitalWrite(B6, HIGH);           }           else
              if(bullets == 2)             {               digitalWrite(BULL, LOW);               digitalWrite(B2, LOW);               digitalWrite(B3, LOW);               digitalWrite(B4, LOW);               digitalWrite(B5, HIGH);               digitalWrite(B6, HIGH);             }             else
                if(bullets == 1)               {
                digitalWrite(BULL, LOW);                 digitalWrite(B2, LOW);                 digitalWrite(B3, LOW);                 digitalWrite(B4, LOW);                 digitalWrite(B5, LOW);                 digitalWrite(B6, HIGH);               }               else
                  if(bullets == 0)                 {
                  digitalWrite(BULL, LOW);                   digitalWrite(B2, LOW);                   digitalWrite(B3, LOW);                   digitalWrite(B4, LOW);                   digitalWrite(B5, LOW);                   digitalWrite(B6, LOW);                 }
  }   else   {     digitalWrite(LED, LOW);   }  }
Yes, thanks
dave-in-nj: read about if() and syntax.
bullets=bullets-1
the sintax is
{ if(this==0);
Ok, thanks
