Copy and Paste 'Code' problem.
Hi, Am having trouble copying and pasting Code to IDE. What happens is when I paste my piece of (copied) code, it comes out repeating itself over and over again (multiple times) It appears to get to the end of the code
and then starts repeating itself, like LOOPING ? I have a feeling I should be copying in Code tags # ? I hope there is a simple solution. Thanks Chaso.
I have no idea why that's happening, but code tags are only for formatting posts here on the forum. Do not put code tags in your source code.
Don't use the broken "Copy for Forum" menu option. Just use "Copy", and "Paste" putting the pasted contents between tags.
Alternatively you can attach your ino file to the post. (Under the "Additional Options twisty").
Thank you James, your advise worked. Chaso.
