Hello all.
I need to do a test validation for something which, if it succeeds, will probably made with hardware.
In short, I have 6 input pulse signals (from an encoder) which I need to put, as quickly as possible, in 6 outputs.
Doing the digitalWrite(....digitalRead(...)) 6x is probably too slow. Is there a faster way to do it?
Thanks
aarg:
Which processor?
Thank you for your quick reply. I'm using a small nano (328P)
Yes, D8-D13 are just PB0-PB5 and D2-D7 are just PD2-PD7. So you can do a port read of PORTB, shift left twice and do a port write to PORTD (first reading and masking the bits for PD0 and PD1 to preserve their values).
TheMemberFormerlyKnownAsAWOL:
Six lengths of wire.
That's it! I wish I thought of that before
Now imagine that I need to do some kind of signal coupling and that I would like to test it with an arduino before I go with hardware components that I would still need to buy. Do you see a way to do it with my nano and my breadboard?
aarg:
Yes, D8-D13 are just PB0-PB5 and D2-D7 are just PD2-PD7. So you can do a port read of PORTB, shift left twice and do a port write to PORTD.
Thank you. I will try it.
aarg:
That worked perfectly (with some surprises - reading PORTB always returns 0, but PINB works just fine).
while(1)
tempB = (PINB & B00111111) << 2;
tempD = PIND & B00000011;
PORTD = tempD | tempB;
Here's why I need this: The original encoder signal has a minimum value of ~~1V and a maximum of ~~4V. I need it to have 0-5V. I needed to test if the equipment which must receive this encoder signal works with 0-5V, because it was not working with 1-4V. It does work
CH1: original signal (sorry for the interferences)
CH2: output on the nano.
At maximum input frequency (51,2kHz) there is a small delay (around 1us) from the input to the output signal but, as far as I could see, it's constant so not a problem.
Thank you very much for your help
Don't forget that clock interrupts are going to introduce jitter.
