char ssid[] = "guest";
String ssidnew = "newssid";
I want to copy String ssidnew to char ssid[]
strcpy() does not work.
Any ideas?
Any ideas?
Look into the toCharArray() function.
The ssid array has 5 elements. The ssidnew array has 7 elements so will not fit in ssid.
Using variable-type String (with capital "S") has its limitations.
me personally I prefer to use PString
This is a library that can be installed with the library-manager of the arduino-IDE
#include <PString.h>
//my personal naming-convemtion adding suffixes "_AoC" for ArrayOfCHar
// and _PS for PString for easy indicating the variabletype
char MyDemo_AoC[20 + 1]; // 20 chars for characters one extra-char for terminating zero
PString MyDemo_PS(MyDemo_AoC, sizeof(MyDemo_AoC));
int MyInt = -12345;
float MyFloat = -9.87654321;
Serial.println("setup start");
MyDemo_PS = "";
Serial.print("MyDemo_PS = ''; contains #");
Serial.print(MyDemo_PS);
Serial.print("#");
MyDemo_PS = "A";
Serial.print("MyDemo_PS = 'A'; contains #");
Serial.print("#");
MyDemo_PS += "2345678";
Serial.print("MyDemo_PS += '2345678'; contains #");
Serial.print("#");
MyDemo_PS += "9";
Serial.print("MyDemo_PS += '9'; contains #");
Serial.print("#");
MyDemo_PS += "ABC";
Serial.print("MyDemo_PS += 'ABC'; contains #");
Serial.print("#");
MyDemo_PS = "123456789012345678901234567890";
Serial.print("MyDemo_PS = '123456789012345678901234567890'; contains #");
Serial.print("#");
MyDemo_PS = MyInt;
MyDemo_PS += " ";
MyDemo_PS += MyFloat;
Serial.print("MyDemo_PS = MyInt + MyFloat ; contains #");
Serial.print("#");
best regards Stefan
