Copying 8bits from PORTA to 4 bits PORTB
Quite a general programmin question.
Say I want to copy the contents of PORTA into PORTB
PORTA = PORTB
Now say I only want the 4 least significant digits copied (the 4 MSB should all be zero).
What the most efficient way to do this? Copy them to a variable, shift them and then copying them from the variable to PORTA?
Regards
PORTB = PORTA & B00001111;
Or
PORTA = PINB & 0b00001111;
Are the bits at the Port B pins inputs or outputs?
CrossRoads:
Or
Thanks guys.
Porb B pins are outputs
Be careful that your code doesn't change bits in a Port that have some other use in the Arduino system. On an Uno some of the 8 bits in every Port are used by something else.
That means that you must use
&= 0b11110000 to clear all 4 low bits without disturbing the 4 high bits
|= 0b00001111 to set all 4 low bits
(hope I have this the right way round)
...R
