copying a stgructure
I have this code:
typedef struct { int Pitch; int FMode; } Payload;
Payload TheData, Xdata;
void GetData() { TheData.Pitch = analogRead(9); TheData.FMode = digitalRead(10); }
Xdata = TheData;
I want to copy TheData to Xdata. I get an error stating
'Xdata' does not name a type
I would think this should work, yes/no?
This compiles without errors
typedef struct {
  int Pitch;
  int FMode;
} Payload;
void GetData()
  Xdata = TheData;
So you have to show more code for us to point out where you went wrong.
If it's all correct, I can't say without testing; but I have my doubts.
To copy, you can use memcpy().
typedef struct {
  int Pitch;
  int FMode;
} Payload;
void GetData()
  memcpy(&Xdata, &TheData, sizeof(Payload));
Because the code is not properly posted, I cannot tell if it is complete. All executable code must be in a function, and a function should not contain a function.
(Yes, there are exceptions, but they don't apply here.)
I would expect to see functions setup, loop, or main.
sterretje: To copy, you can use memcpy().
Since this is C++, for structs/classes a copy constructor is implicitly defined by default. this means that (since this is a simple struct of POD's) you can make the assignment just like any plain old data types:
typedef struct {
  int Pitch;
  int FMode;
} Payload;
  Xdata = TheData;
  Serial.println(F("TheData:"));
  Serial.println(TheData.Pitch);
  Serial.println(TheData.FMode);
  Serial.println(F("Xdata:"));
  Serial.println(Xdata.Pitch);
  Serial.println(Xdata.FMode);
BulldogLowell: Since this is C++, for structs/classes a copy constructor is implicitly defined by default. this means that (since this is a simple struct of POD's) you can make the assignment just like any plain old data types:
Never knew that. I'm still too much of a C programmer and thought it would work the same as C for structs.
I am embarrassed. This is the case where I looked at the simple error over and over and did not see it.
I put the statement Xdata = GetData; outside of the setup procedure. No wonder it didn't work. I will do better.
I didn't add more surrounding code to make the example simple. Like Einstein said, "make things simple but not too simple" or something like that.
You made it too simple :)
barryjo: I put the statement Xdata = GetData; outside of the setup procedure. No wonder it didn't work.
if you want Xdata to always equal TheData:
typedef struct {
  int Pitch;
  int FMode;
} Payload;
Payload TheData;
Payload& Xdata = TheData;
//  Xdata = TheData;
