Hi, I am currently using the HX711 for a project and was wondering where I would be able to find the arduino code that for that library. I just want to see the code to be able to see how exactly the HX711 library calculates values based on the two pins (DT, SCK) to understand how the amplifier works better
The code for the library will be in its folder in the Libraries folder of your sketchbook folder
The easiest way to find it is to open one of the example sketches from the library in the IDE then use Sketch>Show Sketch Folder and navigate up from there in Windows until you get to the library folder. The library code is in the src folder of that directory
