Corect use of pointer?
Hello, I'm having trouble understanding pointers and want to know if I'm on the right track.
I have an array of midi notes and wish to create a C major scale from that array. int notes[13] = { 60,61,62,63,64,65,66,67,68,69,70,71,72 }; Can I use an array of pointers like this int Cmajor = &notes[0,2,4,5,7,9,11,12]; Each value indexes a position within "notes[13]".
If this is correct then I want to check that with the serial monitor but I an completely confused how to write that now after looking at various sites. Here's an embarrassing mess that I have so far..
int *Cmajor;
  Serial.println(Cmajor[0]);
void loop() {}
Obviously doesn't compile... Any help welcome :slight_smile:
What the Hell is that supposed to be?
Cmajor = &notes[0,2,4,5,7,9,11,12]; Even if it made sense, it isn't in a function.
If you want a single reference to individual element in the array:
int &Cmajor = notes[1];
Ok so how I can I check that single element in the serial monitor?
goatboyrobbie:
Serial.println(Cmajor);
Thank you. Can this Cmajor = notes[0,2,4,5,7,9,11,12]; be used to print the referenced elements of " notes[....etc? "
goatboyrobbie:
No, that just not part of the language syntax
Ok so if I want to choose elements of int notes[13] = { 60,61,62,63,64,65,66,67,68,69,70,71,72 }; and use those elements to form a scale of usable notes, because I will eventually want to create many scales, would I use an array of pointers as such? int Cmajor[8] = {0,2,4,5,7,9,11,12};
That looks more like an array of indices
I know I have to be careful now but I think that is what I'm looking for! I want to index "notes..."
goatboyrobbie:
If you want to have a subset of your original array, you can do:
int *notesSubSet = &notes[2];
Then the first element of "notesSubSet" will be the third element of "notes"
And if I want to include multiple elements in that subset?
goatboyrobbie:
That subset is a continuous array of your original set.
So subset[0] is notes[2]
subset[1] is notes[3]
subset[2] is notes[4]
Ok cool! Thanks Arduino_new!
