This is a deliberately blocking test function which is why it doesn't matter about delays. I am sending the main code three times and following it with an "End of transmission" code 0x5121. That all works.
The volume control should not have the EOT code sent, so I wrote a little If test which stops the EOT being transmitted at all for some reason. Being at work I KEEP being interrupted >:( so can't see the wood for the trees. Could someone advise me where I have cocked it up please?
// ************************ Cycle through Sony IR codes transmit ********************************
void proc_transmitTest() {
// Uses A6 to sense whether to engage test mode. If high, normal. Low = run test on continuous loop.
unsigned long endData = 0x5121; // Release code sent at the end of the burst.
for (int x = 0; x < 21; x++) {
unsigned long tData = (Sony [x]); //Look up the next code from the array 'Sony'.
for (int i = 0; i < 3; i++) {
irsend.sendSony(tData, 15); // Send key data three times
Serial.print(F("sendSony(0x"));
Serial.print(tData, HEX);
Serial.println(F(", 15)"));
delay(40);
tData++;
delay(1500);
// if ((tData)==!0x2421 && !0x6421) { // If volume up or down, don't send EOT
irsend.sendSony(endData, 15); // Send release code once
Serial.print(endData, HEX);
delay(40);
delay(5000); //5 second delay between each signal burst
if ((tData)==!0x2421 && !0x6421)^
is odd
I guess it should be
if ( ((tData) != 0x2421) && ((tData) != 0x6421) )
best regards Stefan
Cock up #1 is not posting a complete sketch so that the problem can be seen in context
tData++;
Why? It's not going to make checking the value of tData any easier.
if ((tData) == !0x2421 && !0x6421)
The '!' operator is a LOGICAL NOT. Since "0x2421" is not 0 it is 'true'. Therefore, "!0x2421" is 'false' or 0. Same for "!0x6421" evaluating to false/0.
That makes the expression equivalent to:
if ((tData == 0) && false)
That will always be 'false'.
When you want the comparison "is not equal to" you use the '!=' operator:
if (tData != 0x2421 && tData != 0x6421)
john you are right thanks for correcting
UKHeliBob:
I beg to differ. I was asking only about the correct syntax of one line, not for help with any other aspect of the program. If I were to post it all, it would be as an attachment and it would not compile anyway without the local libraries and a modified public library. So in this case, although I understand your point, we will have to agree to disagree.
johnwasser:
Thanks John. That has sorted out my confusion.
After looking at my coding again and using the correct syntax this time, I noticed that I was using a sledgehammer to crack a nut. The value of 'X' was all I needed to test for!
Thanks again for everyone's kind and helpful advice.
I agree entirely with your comments about posting a large sketch with library dependencies but that was not what I suggested. You posted an isolated function and you could have posted a small sketch incorporating that function which illustrated the problem that you were having by calling the function with appropriately valued variables
