From every thing that I have read Strings is very bad so I am doing my best to get away from them
So what is the Best/Correct way to handle byte* info?
Scenario: When I receive a payload from an MQTT topic I would like to compare the payload ( The payload must be a 1 or 5 ) and then according to that payload the do the next function.
by creating String from the payload I have managed to get it going but then I came across atoi - will using this function be the correct way?
Here is my working code so far :
Basic MQTT example
This sketch demonstrates the basic capabilities of the library.
It connects to an MQTT server then:
 - publishes "hello world" to the topic "outTopic"
 - subscribes to the topic "inTopic", printing out any messages
  it receives. NB - it assumes the received payloads are strings not binary
It will reconnect to the server if the connection is lost using a blocking
reconnect function. See the 'mqtt_reconnect_nonblocking' example for how to
achieve the same result without blocking the main loop.
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
byte mac[]Â Â = {Â 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress ip(192, 168, 6, 99);
IPAddress server(192, 168, 6, 30);
void callback(char* topic, byte* payload, unsigned int length) {
 Serial.print("Message arrived [");
 Serial.print(topic);
 Serial.print("] ");
 for (int i=0;i<length;i++) {
  Serial.print((char)payload[i]);
 byte value = atoi((char*)payload);
 Serial.print(F("atoi:"));
 Serial.println(value);
if (value >0){Â Â Â Â Â Â Â Â Â // if this is 0 then there was TEXT in the payload before the number
 if (value == 5){
 Serial.println("Payload 5 Recieved");
}else if (value == 1){
 Serial.println("Payload 1 Recieved");
Â
Â
EthernetClient ethClient;
PubSubClient client(ethClient);
void reconnect() {
 // Loop until we're reconnected
 while (!client.connected()) {
  Serial.print("Attempting MQTT connection...");
  // Attempt to connect
  if (client.connect("arduinoClient")) {
   Serial.println("connected");
   // Once connected, publish an announcement...
   client.publish("outTopic","hello world test");
   // ... and resubscribe
   client.subscribe("inTopic");
   Serial.print("failed, rc=");
   Serial.print(client.state());
   Serial.println(" try again in 5 seconds");
   // Wait 5 seconds before retrying
   delay(5000);
 Serial.begin(57600);
 client.setServer(server, 1883);
 client.setCallback(callback);
 Ethernet.begin(mac, ip);
 // Allow the hardware to sort itself out
 delay(1500);
 if (!client.connected()) {
  reconnect();
 client.loop();
