Correct way of "NOT" in Arduino/C
(I'm typing it out right here, so this is not about errors, more the "correct way")
for example.
boolean SomeCondition = false;
   //Let's toggle SomeCondition.
  SomeCondition = !SomeCondition;
 or is it
  SomeCondition = NOT SomeCondition;
Which is the correct way to flip the state? - i'm not even sure NOT compiles... I just remember having
issues trying to invert the value and ended up using if (SomeCondition==true) .... SomeCondition=false else .... SomeCondition=true;
I'm in the middle of waiting for an 800 galaxy 2 image to download, so i'm taking a quick break while it finishes.
Bang. NOT is for Pascal (and other verbose languages).
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
boolean LEDState = false;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  LEDState = !LEDState;
  digitalWrite(led, LEDState);   // turn the LED on (HIGH is the voltage level)
  // wait for a second
  digitalWrite(led, LEDState);    // turn the LED off by making the voltage LOW
  delay(1000);               // wait for a second
This be the way then.... I think the first time i Tried it (never tried a not since because it never worked, so i used logical if conditions....) well, I think I must have missed out a 2nd delay to see the inverted signal and because of the no delay, it went back to a high state....
This was several months back, good to see it work! :slight_smile:
yeah yeah
I know....
