I am using the DOGm128s6 display, I have tried using the "DOG_7565R.h" library as well as u8g2lib.h
I purchased the display from Mouser, I don't see how that even matters!
my code is from the manufactures website
#include <Arduino.h>
#include <SPI.h>
#include <dog_7565R.h>
#include <font_16x32nums.h>
#include <font_6x8.h>
#include <font_8x16.h>
#include <font_8x8.h>
#include <logo_BLH.h>
/*Available functions in dog_7565R Libraray:
void initialize (byte p_cs, byte p_si, byte p_clk, byte p_a0, byte p_res, byte type);
void clear (void);
void contrast (byte contr);
void view (byte direction);
void string (byte column, byte page, const byte *font_adress, const char *str);
void rectangle (byte start_column, byte start_page, byte end_column, byte end_page, byte pattern);
void picture (byte column, byte page, const byte *pic_adress);
dog_7565R DOG;
//the following port definitions are used by our demo board "EA PCBARDDOG7565"
int led = 3;
int led_red = 3;
int led_green = 5;
int led_blue = 6;
int Sat;
void init_backlight(boolean mono);
void mono_backlight(byte brightness);
void rgb_backlight(byte red, byte green, byte blue);
void sample_screen(void);
//initialize the backlight and the display
init_backlight(true); //use monochrome backlight in this sample code. Please change it to your configuration
DOG.initialize(10,0,0,9,4,DOGM128); //SS = 10, 0,0= use Hardware SPI, 9 = A0, 6 = RESET, EA DOGM128-6 (=128x64 dots)
//create a sample sceen content
Sat = 5;
DOG.clear(); //clear whole display
DOG.picture(0,0,ea_logo);
DOG.string(71,0,font_8x16,"DOGM128"); //font size 8x16 first page
DOG.rectangle(71,2,127,2,0x03); //show small line (filled pattern = 0x03), to the left and right of 'DOGM128'
DOG.string(0,4,font_6x8,"-ST7565R controller");
DOG.string(0,5,font_6x8,"-different backlights");
DOG.string(0,6,font_6x8,"-extrem low power");
DOG.string(0,7,font_8x8,"lcd-module.com");
//main loop
mono_backlight(255); //BL to full brightness
DOG.view(VIEW_BOTTOM); //default viewing direction
sample_screen(); //show content
delay(2000);
mono_backlight(128); //BL to half brightness
// DOG.view(VIEW_TOP); //alternate viewing direction
sample_screen();
delay(2000);
//The following functions controll the backlight with a PWM. Not needed for the display content
if(mono) //EA LED55X46-G, EA LED55X46-W, EA LED55X46-B, EA LED55X46-A, EA LED55X46-R, EA LED55X46-E
pinMode(led, OUTPUT);
else //EA LED55X46-RGB
pinMode(led_blue, OUTPUT);
pinMode(led_green, OUTPUT);
pinMode(led_red, OUTPUT);
rgb_backlight(255,0,0);
//Use this funtion for monochrome backlight
analogWrite(led, brightness);
//Use this function for RGB backlight
analogWrite(led_red, red);
analogWrite(led_green, green);
analogWrite(led_blue, blue);
Rick
