I hope this is the right forum for this question, but I have been running into trouble with my MAX31855 sensor data.
I have a custom arduino Leonardo board to control a coffee roaster. In my design the arduino connects to two MAX31855 through a shared SPI bus (different chip select per MAX31855). I am sending the sensor data through the USB-serial port to connect to a software program that uses this data for controlling heating elements, motors, and display (through I2C).
I have found when I either use the Serial.print for debugging purposes or to speak with the program; my sensor data gets corrupted (seems to divide in half). The display and serial interface show the same incorrect data. If I don't connect through Arduino serial monitor or open a UART connection sensor data is correct on my display.
I don't know the Serial.print is interrupting my SPI transaction or corrupting the register data. But if I have less debug data there errors are less common.
In my code below I don't show the entire state machine as it would blow up the code a lot.
Pretty crappy coffee roasting code. That is all
Written by Nathan Slattengren.
BSD license, all text above must be included in any redistribution
This is revision 8 of the design and supports connecting to a convection oven. See Revision 7 for the last support of coffee roaster.
#include <SPI.h>
#include <Wire.h>
#include "Adafruit_MAX31855.h"
#include "LCD16x2.h"
#include "coffee_roaster.h"
LCD16x2 lcd;
int PreviousButton;
int CurrentButton;
// Default connection is using software SPI, but comment and uncomment one of
// the two examples below to switch between software SPI and hardware SPI:
// Example creating a thermocouple instance with software SPI on any three
// digital IO pins.
#define MAXDO 0
#define MAXCS1 1
#define MAXCS2 4
#define MAXCLK 30 // The TX LED has a defined Arduino pin
#define RELAY_PIN 6
#define FAN_PIN 5
#define MOTOR_PIN 11
#define LED_GREEN 8
// initialize the Thermocouple
Adafruit_MAX31855 thermocouple1(MAXCLK, MAXCS1, MAXDO);
Adafruit_MAX31855 thermocouple2(MAXCLK, MAXCS2, MAXDO);
//Defines
float Setpoint;
//Run a fake temperature increase
boolean simulation = false;
boolean linear = true;
float Input_simulation = 75;
//Do a pre-heat before roasting?
boolean preheat = true;
unsigned long startMillis;
unsigned long now; //Register for the current time at the start of each loop
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
#define Serial SerialUSB
#endif
Wire.begin();
pinMode(RELAY_PIN, OUTPUT);
pinMode(FAN_PIN, OUTPUT);
pinMode(MOTOR_PIN, OUTPUT);
pinMode(MAXCLK, OUTPUT);
pinMode(LED_GREEN, OUTPUT);
analogWrite(RELAY_PIN, 0);
analogWrite(FAN_PIN, fan_val);
analogWrite(MOTOR_PIN, motor_val);
//Flash the start screen
display_start();
noInterrupts(); // disable all interrupts
/** initialize timer1 The point of the timer is to give 250ms trigger
Caluclation is 1/16MHz * 15625 * 256 = 250ms
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 15625; // compare match register 16MHz/256/4Hz
TCCR1B |= (1 << WGM12); // CTC mode
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
interrupts(); //allows interrupts
startMillis = millis(); //initial start time for ADC sample routine
//wait for MAX chip to stabilize if simulation is not happening
if (simulation) {
lcd.lcdClear();
int roasting_started = 0;
int cooling_started = 0;
unsigned long time_start = 0;
int count = 0;
int SaveState = 0;
int LEDBlink = 1;
boolean RELAY = false;
int x1 = 0;
digitalWrite(LED_GREEN, LEDBlink);
LEDBlink = !LEDBlink;
now = millis();//Grab time at start of loop
//Routine to sample the ADC every 250ms. The MAX31855 takes up to 100ms per sample to have stable data
if(interrupt_trigger_flag = true){
if(sample_temp1 == true){
Input1 = get_temp(Input1,sample_temp1);
x1 = round(Input1);
if (Input1 < 10) sprintf(Input_buffer," %d", x1);
else if (Input1 <= 99) sprintf(Input_buffer," %d", x1);
else if (Input1 > 99) sprintf(Input_buffer,"%d", x1);
else {
Input2 = get_temp(Input2,sample_temp1);
sample_temp1 = !sample_temp1;
//Go ahead and write values to LCD
refreshlcd();
interrupt_trigger_flag = false;
if (check_buttons_flag >= 1){
check_buttons_flag = 0;
if (button_changed_flag == 1){
CurrentButton = 15;
button_changed_flag = 0;
else {
PreviousButton = CurrentButton;
CurrentButton = lcd.readButtons();
if (CurrentButton != PreviousButton) {button_changed_flag = 1;
else CurrentButton = 15;
handleSerialCommand();
switch (CurrentState) {
case state_idle:{
RELAY = false;
motor_val = 0;
if(CurrentButton == 15) CurrentState = state_idle;
else if (CurrentButton == 14) CurrentState = state_idle_transition;
else if (CurrentButton == 3) CurrentState = state_idle_to_debug_transition;
else CurrentState = state_idle;
thermal_power_button();
case state_idle_transition: {
lcd.lcdClear();
if (preheat == true) CurrentState = state_preroast;
else CurrentState = state_roasting;
idle_state_flag = false;
fan_val = 255;
fan[4] = "255";
motor_val = 255;
case state_idle_to_debug_transition:{
lcd.lcdClear();
CurrentState = state_debug;
char roast[4] = "00";
int roast_val = 0;
int fan_val = 0;
//fan1_ramp_up(4);
case state_preroast: {
motor_val = 0; //don't turn on motor yet
if (roasting_started == 0) {
roasting_started = 1;
time_start = now;
else roast_time = (now - time_start);
analogWrite(RELAY_PIN, roast_val);
RELAY = true;
if (!(CurrentButton & 0x02)) CurrentState = state_preroast_transition;
else CurrentState = state_preroast;
case state_preroast_transition:
lcd.lcdClear();
preroast_state_flag = false;
roast_time = 0;
case state_roasting: {
time_start = now;
RELAY = true;
if (!(CurrentButton & 0x02)) CurrentState = state_roasting_transition;
case state_roasting_transition:
lcd.lcdClear();
roasting_state_flag = false;
CurrentState = state_cooling;
roast_time = 0;
case state_cooling: {
RELAY = false;
//analogWrite(FAN_PIN, 255);
Setpoint = 45;
if (cooling_started == 0) {
cooling_started = 1;
time_start = now;
else{
cool_time = (now - time_start);
if(Input1 > Setpoint){
CurrentState = state_cooling_transition;
else if((Input1 < Setpoint) || (Input1 == Setpoint))
case state_cooling_transition:
lcd.lcdClear();
cooling_state_flag = false;
cool_time = 0;
fan_val = 0;
fan[4] = " 0";
motor_val = 0;
case state_debug: {
RELAY = true;
//analogWrite(FAN_PIN, fan_val);
if(CurrentButton == 12) CurrentState = state_debug_transition;
else CurrentState = state_debug;
fan_button();
case state_debug_transition:
lcd.lcdClear();
debug_state_flag = false;
void display_start() {
lcd.lcdClear();
lcd.lcdGoToXY(3,1);
lcd.lcdWrite("Barrel Man v11");
lcd.lcdGoToXY(1,2);
lcd.lcdWrite("Coffee Roasting");
delay(750);
void thermal_power_button(){
if(!(CurrentButton & 0x08)) {
if (roast_val == 255) roast_val = 00;
else roast_val++;
if (roast_val < 10) sprintf(roast, " %d",roast_val);
else if (roast_val < 100) sprintf(roast, " %d",roast_val);
else sprintf(roast, "%d", roast_val);
else if (!(CurrentButton & 0x04)) {
if (roast_val == 00) roast_val = 255;
else roast_val--;
void fan_button(){
if(!(CurrentButton & 0x02)) {
if (fan_val == 255) fan_val = 00;
else fan_val++;
if (fan_val < 10) sprintf(fan, " %d",fan_val);
else if (fan_val < 100) sprintf(fan, " %d",fan_val);
else sprintf(fan, "%d", fan_val);
else if (!(CurrentButton & 0x01)) {
if (fan_val == 00) fan_val = 255;
else fan_val--;
//This function is to convert the millis to a readable min:sec format
char conv_currtime_disp(unsigned long input_milli){
unsigned long allSeconds=input_milli/1000;
int secsRemaining=allSeconds%3600;
int runMinutes=secsRemaining/60;
int runSeconds=secsRemaining%60;
if (roasting_started == 1) sprintf(roast_time_char,"%02d:%02d",runMinutes,runSeconds);
else if (cooling_started == 1) sprintf(cool_time_char,"%02d:%02d",runMinutes,runSeconds);
void handleSerialCommand(){
if (Serial.available()>0){
String msg = Serial.readStringUntil('\n');
if (msg.indexOf("CHAN;")== 0){ //Ignore this Setting
Serial.print("#OK");
else if (msg.indexOf("UNITS;")== 0){
if (msg.substring(6,7)=="F"){ //Change to Farenheit
unit_F = true;
Serial.println("#OK Farenheit");
else if (msg.substring(6,7)=="C"){ //Change to Celsius
unit_F = false;
Serial.println("#OK Celsius");
else if (msg.indexOf("READ")==0){ //Send Temps
Command_READ();
else if (msg.indexOf("FILT")== 0){
//Send Data
void Command_READ(){
Serial.print("0.00,"); //ambient
Serial.print(Input1);
Serial.print(",");
Serial.print(Input2);
Serial.println(",0.00,0.00");
void fan1_ramp_up(int step_size) {
fan_val = 0;
for (int i = 0; i <= 35; i++) {
fan_val = fan_val+step_size;
delay(10); //To give time for the current to settle after step
ISR(TIMER1_COMPA_vect) {
interrupt_trigger_flag = true;
check_buttons_flag++;
//The state flags are set so the second time around it doesn't refresh the entire display
void refreshlcd(){
if (CurrentState == state_idle) {
display_idle();
idle_state_flag = true;
/*Serial.print(F(",Ambient,"));
Serial.print(thermocouple.readInternal());
Serial.print(F(",Temp,"));
Serial.println(Input1);
Serial.print("Humidity:");
Serial.print(humidity);
Serial.println("%");*/
else if (CurrentState == state_roasting) {
Serial.print(F(",roast value,"));
Serial.println(roast);*/
conv_currtime_disp(roast_time);
display_roasting();
roasting_state_flag = true;
else if (CurrentState == state_cooling) {
/* Serial.print(F(",Ambient,"));
Serial.println(Input1);*/
conv_currtime_disp(cool_time);
display_cooling();
cooling_state_flag = true;
else if (CurrentState == state_preroast) {
Serial.println(CurrentState);*/
display_preroast();
preroast_state_flag = true;
else if (CurrentState == state_debug) {
display_debug();
debug_state_flag = true;
void display_idle() {
if (idle_state_flag == false) {
lcd.lcdGoToXY(1,1);
lcd.lcdWrite("Idle ");
lcd.lcdGoToXY(7,1);
lcd.lcdWrite("Temp = ");
lcd.lcdGoToXY(14,1);
lcd.lcdWrite(Input_buffer);
lcd.lcdGoToXY(1,2);
lcd.lcdWrite("Start? ");
lcd.lcdGoToXY(8,2);
lcd.lcdWrite("PWR = ");
lcd.lcdGoToXY(14,2);
lcd.lcdWrite(roast);
else {
void display_preroast() {
if (preroast_state_flag == false){
lcd.lcdGoToXY(1,1);
lcd.lcdWrite("Heat ");
lcd.lcdGoToXY(7,1);
lcd.lcdGoToXY(1,2);
lcd.lcdWrite(roast_time_char);
lcd.lcdGoToXY(6,2);
lcd.lcdWrite(" End?");
lcd.lcdGoToXY(12,2);
lcd.lcdWrite(" ");
else {
lcd.lcdGoToXY(1,2);
void display_roasting() {
if (roasting_state_flag == false){
lcd.lcdGoToXY(1,1);
lcd.lcdWrite("Roast ");
lcd.lcdGoToXY(7,1);
lcd.lcdGoToXY(1,2);
lcd.lcdGoToXY(6,2);
lcd.lcdWrite(" Stop?");
lcd.lcdWrite(" ");
else {
lcd.lcdGoToXY(1,2);
void display_cooling() {
if (cooling_state_flag == false){
lcd.lcdGoToXY(1,1);
lcd.lcdWrite("Cool ");
lcd.lcdGoToXY(7,1);
lcd.lcdGoToXY(1,2);
lcd.lcdWrite(cool_time_char);
lcd.lcdGoToXY(6,2);
lcd.lcdWrite(" ");
else {
lcd.lcdGoToXY(1,2);
void display_debug() {
if (debug_state_flag == false){
lcd.lcdGoToXY(1,1);
lcd.lcdWrite("Debug ");
lcd.lcdGoToXY(7,1);
lcd.lcdGoToXY(1,2);
lcd.lcdWrite("Fan ");
lcd.lcdGoToXY(5,2);
lcd.lcdWrite(fan);
lcd.lcdGoToXY(8,2);
lcd.lcdWrite(" SSR ");
else {
lcd.lcdGoToXY(5,2);
lcd.lcdWrite(fan);
float get_temp(float temp,boolean read_sensor_one) {
float c;
if (!simulation){
if (unit_F == true) {
if(read_sensor_one == true) c = thermocouple1.readFahrenheit();
else c = thermocouple2.readFahrenheit();
else {
if(read_sensor_one == true) c = thermocouple1.readCelsius();
else c = thermocouple2.readCelsius();
if (isnan(c))
c = temp;
else c = (c + temp)/2;
else c = simulation_temp();
return c;
float simulation_temp(void) {
if (CurrentState == 0) {
count = 0;
if ((Input_simulation > 0) || (Input_simulation < 78)) Input_simulation = 77;
else Input_simulation = (Input_simulation - Input_simulation/9);
else {
if (RELAY == false) {
if (Input_simulation > 77 && Input_simulation < 100 ) Input_simulation = Input_simulation-0.0089;
else if (Input_simulation > 100 && Input_simulation < 125 ) Input_simulation = Input_simulation-0.0128;
else if (Input_simulation > 125 && Input_simulation < 150 ) Input_simulation = Input_simulation-0.0321;
else if (Input_simulation > 150 && Input_simulation < 200 ) Input_simulation = Input_simulation-0.081;
else if (Input_simulation > 200 && Input_simulation < 250 ) Input_simulation = Input_simulation-0.12;
else if (Input_simulation > 250 && Input_simulation < 300 ) Input_simulation = Input_simulation-0.14;
else if (Input_simulation > 300 && Input_simulation < 350 ) Input_simulation = Input_simulation-0.16;
else if (Input_simulation > 350 && Input_simulation < 400 ) Input_simulation = Input_simulation-0.18;
else if (Input_simulation > 400 && Input_simulation < 450 ) Input_simulation = Input_simulation-0.2;
else if (Input_simulation > 450 && Input_simulation < 500 ) Input_simulation = Input_simulation-0.22;
else Input_simulation = Input_simulation;
else {
if (linear) {
if (Input_simulation < 100) Input_simulation = Input_simulation + 0.024;
else if (Input_simulation > 100 && Input_simulation < 150) Input_simulation = Input_simulation + 0.022;
else if (Input_simulation > 150 && Input_simulation < 200) Input_simulation = Input_simulation + 0.018;
else if (Input_simulation > 200 && Input_simulation < 250) Input_simulation = Input_simulation + 0.014;
else if (Input_simulation > 250 && Input_simulation < 300) Input_simulation = Input_simulation + 0.0081;
else if (Input_simulation > 300 && Input_simulation < 350) Input_simulation = Input_simulation + 0.0061;
else if (Input_simulation > 350 && Input_simulation < 375) Input_simulation = Input_simulation + 0.00321;
else if (Input_simulation > 375 && Input_simulation < 400) Input_simulation = Input_simulation + 0.00128;
else if (Input_simulation > 400 && Input_simulation < 425) Input_simulation = Input_simulation + 0.00089;
else if (Input_simulation > 425 && Input_simulation < 500) Input_simulation = Input_simulation + 0.000357;
else {
Input_simulation = 0.0005*pow(count,3)-0.1257*pow(count,2)+11.012*count +51.339;
count++;
return Input_simulation;
